datadesk MAC-101 SMK White Slider ADB Keyboard
rzwv
06 Dec 2012, 17:08
This keyboard is ABD connection. Using iMate, it is used in Windows OS.
It is tactile. It is as heavy as Cherry MX White.
The spring is contained in the space bar and it is heavy.
このキーボードはABD接続です。iMateを使用し、Windows OSにて使用しています。
タクタイルです。Cherry MX Whiteと同じくらい重たいです。
スペースバーにはバネが入っており、重たくなっています。
Other pictures.
http://kbd.rzw.jp/mechanical/datadesk_mac-101/
06 Dec 2012, 23:40
That's interesting. Those switch internals are very similar to Monterey, with the "baling wire" as Ripster put it. If SMK didn't make the Monterey, then whoever copied SMK's switch housing style also copied their mechanism as well.
By the way, SMK is completely unrepresented on the Deskthority wiki. You should really upload those photos and create a page for the keyboard and for the switch.
Not sure what to call it though. You'll need a category "SMK switches". But the page name? Anyone have a preference for what we call this particular style of switch? SMK also did Alps clones for example, as well as other styles. (Apparently SMK is Strong Man Keyboard.)
Also, what is the pin arrangement? Is it compatible with Alps or Aruz?
(And a Ping Award 2012 runner up prize can go to Datadesk for a blatantly wrong keyboard layout for Macs, and for mixing up "Mac" and "MAC" a-gain.)
REVENGE
07 Dec 2012, 21:06
Sweet, they even have the modern SMK logo!
08 Dec 2012, 02:55
YIB. Yellowed in box.
I've got this Tulip keyboard for comparison, which is even more yellowed.
08 Dec 2012, 02:59
Do yours have the same internals? (Just in case one is a clone ;-)
Also, are they actually U mount?
*really hoping* that rzvw will post all his details to the wiki, as it's so fascinating how similar these appear to be to Montereys.
08 Dec 2012, 03:13
I never opened mine. I'm sure I've seen them posted elsewhere too in another keyboard (was it geekhack? was it sandy55?) and it also had the SMK logo in the back. Not sure if they are fully MX compatible. Have been pretty much ignoring it, except that it is actually a very nice clicky switch if I remember correctly.
aremizu
08 Dec 2012, 05:14
I own SONY PCY-333 of the same Japanese as this.
In addition, the keyboard include the switch called "Monterey" is also owned.
I think that "Monterey" is not a copy but a switch of SMK, seeing the structure and the parts of a switch.
-13:27(JST) Add
These switches differ in feedback.
SONY QuarterL PCY-333 = SMK + Switch / tactile
more info : http://www7.ocn.ne.jp/~hisao/image/pcy333.htm
Chicony KB-9600 = Monterey(SMK) [] Switch (ALPS compatible) / clickey
more info : http://sandy55.fc2web.com/keyboard/chicony_kb-5181.html
Cherry compatible model (A leaf spring is the same) : http://sandy55.fc2web.com/keyboard/dtk_mbk1013.html
