http://blog.fsck.com/2013/01/pinkies-an ... brain.html
The thumb keys - most definitely. Just like on any other keyboard1. There is a lot of redundancy (arrows on both hands, thumb keys). Is that by design?
What do you use control-alt-shift-arrow for?I can see how you could get around any bad thumb combos in this arrangement, by hitting two adjacent keys with each thumb. Combo of horror = Ctrl+Alt+Shift+ArrowKeys
Well, , . / are all in their "traditional" non-chorded locations.2. Punctuation could be relocated for improved ergonomics on the blue shift layer? - , . / all used a lot.
Right. Giving my pinkies a break was my main design criterion.
3. I take it the hands are not supposed to 'float' in this kind of a layout (move left and right)? Why no outside keys for the pinkies? (caps lock, ' ) The matrixes I've been working with always have 6 columns per hand. Gonna have to read your blog post.
It's certainly possible, but that starts to get closer to reimplementing The Bat than I'm going for.mikekuehn wrote:Shift+BlueShift could add another layer to relocate some special characters into more ergonomic positions. For instance < > to the top row with the other brackets. As you can tell I'm not a big fan of the downward reach on those fingers. But what should be the penalty for additional chording? With thumb keys it should be less than with pinky modifiers...
They're more comfortable for me than they are on a traditional Sholes layout. Remap it and give it a tryTDub wrote:Mmmh how is the comfort level for {} and [] on this layout. Since I am a programmer, those are kinda the keys I worry about the most on the Ergo Dox since there isn't really space for them right of the letters.
I'm using a Soarer's Mod Convertor ($40 for a premade one on eBay) to adapt my PS/2 Kinesis to USB and my goal is to remap all the keys using it instead of the Kinesis' built in remapping as I noticed there are noticeable delays when typing once I've remapped any characters using the built in "Reprogram" button. Since the PS/2 Kinesis also supports NKRO and the Soarer's happily passes that through I can use some chording as well without worrying about hitting a 6 key limit.eviltobz wrote: This sort of blue shift layout looks pretty nice, and I'll be trying something similar with my Ergodox, but I'm not sure if there is any way to get it running on my Kinesis. It has the embedded keypad layer which would be a good contender, but I don't think that there is any way to move the keypad button. Any other Kinesis users who've managed such a thing? If it makes a difference it's an old classic model with the ps/2 connector so may have been superseded in programmability by the newer ones. I use it on my Windows 7 pc at work, so some hefty AltGr mapping in the microsoft keyboard layout tool may be an option I suppose, but I'd rather do it in the keyboard itself if at all possible.
I also own an old PS/2 Kinesis. I read in two places that also PS/2 models are "just" 6-KRO and in one place that they are NKRO. Anyone can confirm? Anyway 6-KRO is largely sufficient for most needs, I suppose. Unfortunately, on my Kinesis, the right section of rubber switches died, including the Program key, so that it's now basically stuck to the default QERTY layout. I'd be interested to hear about any experience with the Soarer's Mod Convertor, as it would allow me to revive the keyboard. I had tried remapping the whole keyboard layout with AutoHotkey, but trying to make it work as I wanted was a pain and at some point I gave up. BTW, if the forum rules allow, could someone post a link to a ready-made Soarer's Mod Converter?dragon788 wrote:I'm using a Soarer's Mod Convertor ($40 for a premade one on eBay) to adapt my PS/2 Kinesis to USB and my goal is to remap all the keys using it instead of the Kinesis' built in remapping as I noticed there are noticeable delays when typing once I've remapped any characters using the built in "Reprogram" button. Since the PS/2 Kinesis also supports NKRO and the Soarer's happily passes that through I can use some chording as well without worrying about hitting a 6 key limit.eviltobz wrote: This sort of blue shift layout looks pretty nice, and I'll be trying something similar with my Ergodox, but I'm not sure if there is any way to get it running on my Kinesis. It has the embedded keypad layer which would be a good contender, but I don't think that there is any way to move the keypad button. Any other Kinesis users who've managed such a thing? If it makes a difference it's an old classic model with the ps/2 connector so may have been superseded in programmability by the newer ones. I use it on my Windows 7 pc at work, so some hefty AltGr mapping in the microsoft keyboard layout tool may be an option I suppose, but I'd rather do it in the keyboard itself if at all possible.
