Keyboard layout design templates
Kurk
21 Jan 2013, 22:27
Are you one of those people who are not quite happy with standard layouts? Do you scribble your ideas for alternatives on the back of some old envelopes? Here's something for you: keyboard layout design templates. For you to fill in.
Included are the following schematics, all in one PDF and as separate SVG files.
  1. 5x15 matrix
    6x16 matrix
    7x15 matrix
    8x16 matrix
    60% keyboard, e.g. KBC Poker or KBT Pure
    75% keyboard, KBT Race layout
    75% keyboard, Noppoo Choc Mini layout
    Ergo Dox
    Happy Hacking Keyboard Pro 2
    Kinesis Advantage
    Phantom 7bit layout
    Tenkeyless, ISO, 1.25U modifiers
    Tenkeyless, ISO, 1.5U modifiers
    Tenkeyless, US-ANSI, 1.25U modifiers
    Tenkeyless, US-ANSI, 1.5U modifiers
    µTron (microTron)
Example:
Have fun!
Templates_SVG_files.zip
(244.24 KiB) Downloaded 305 times
Keyboard layout design templates.pdf
(421.12 KiB) Downloaded 331 times
BimboBB
22 Jan 2013, 16:30
Many thanks. Is it possible to have these templates as photoshop or illustrator files?
Kurk
22 Jan 2013, 17:34
Illustrator should be able to open the SVG files. I could also convert them to EPS which photoshop can read. Busy atm, so tomorrow at the earliest.
BTW, let me know if you spot any mistakes.
BimboBB
22 Jan 2013, 18:07
Sorry, yre right...works with Illustrator. No need than for converting.
