i always had this question.
does Apple keyboard's Cmd key actually send a different scancode than PC's Win key?
similar question for the F13, F14, F15, vs the Print Screen, Scroll lock, pause/break.
thanks.
Apple keyboard scancode question, Cmd, F13
- Main keyboard: Truly Ergonomic
- Main mouse: Microsoft Explorer
- kps
- Main keyboard: Kinesis contoured
- Main mouse: Kensington Slimblade trackball
The Command keys are identical to the Windows keys (and the Meta keys on Sun keyboards); collectively they are the USB "GUI" keys.
For F13 – F15, Apple keyboards send the USB codes for F13 – F15. USB has assigned codes up to F24, so any keyboard with those labels should send those codes.
For more details including the specific codes, see HID Usage Tables available at http://www.usb.org/developers/hidpage#HID_Usage.
- ne0phyte
- Toast.
- Main keyboard: HHKB Pro 2
- Favorite switch: Topre 45g, MX Blue
- DT Pro Member: 0003
Or for Windows specifically check the Windows Virtual Keycodes
http://msdn.microsoft.com/en-us/library ... s.85).aspx.
thanks a lot guys.
