I just miss the other 80-and-so keys... but the arduino and the software work, that's what I wanted to try
My first custom keyboard
- Mrinterface
- Main keyboard: UHK
- Main mouse: G203
- Favorite switch: Monterey blues
- DT Pro Member: 0012
A true minimalists keyboard... Literally...
Makes me think about my 'keyboard'. It should be called 'keysboard'
Next step up for your project : connect a relais to it and use the switch to turn on/off your computer
- fossala
- Elite +1
- Main keyboard: HHKB Type-S
- Main mouse: Rollermouse Free2
- Favorite switch: Topre
Yeah, saw that. How much different is it to the uno or a teensy?matt3o wrote:that is an arduino micro which very close to a teensy (with some added features). I needed quite a bit of time to sort it out, but I'm taming it.
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
for a keyboard lover the best for prototyping would probably be the Arduino Leonardo ( http://arduino.cc/en/Main/ArduinoBoardLeonardo ). Easy access to the pins and built in mouse and keyboard support.
The arduino micro is the small version of the arduino leonardo, it misses a lot of features but you can use it in the final product.
The teesny and arduino micro share the same CPU and they are actually very similar. Teensy is slightly smaller, arduino micro I believe it has an included voltage regulator and can output 3v out of the box which sometimes is very handy.
- matt3o
- -[°_°]-
the difference is that Leonardo is already a HID device (mouse, keyboard, joypad, ...). Uno must be re-programmed to behave like a HID. It is feasible, but it's a lot of stress if you are an electronics noob such as myself.
Some links that might help you out
http://pbambridge.brunelweb.net/blog/?p=1
http://mitchtech.net/arduino-usb-hid-keyboard/
http://hunt.net.nz/users/darran/weblog/ ... on_03.html
- matt3o
- -[°_°]-
nope, they are not the same.
I can find it only on the official store
http://store.arduino.cc/eu/index.php?ma ... cts_id=245
- Soarer
- Favorite switch: F
The nano uses the '328 chip. The micro and leonardo use the same chip as the teensy - '32U4. The 'U' presumably stands for USB
There was someone selling them on ebay uk (181040107053) - maybe they're just out of stock at the moment.
- matt3o
- -[°_°]-
you can also find a clone called "Pro Micro" which is a teensy size board recognized as a Leonardo, but I know nothing about it.
- matt3o
- -[°_°]-
absolutely not! that's what it's all aboutpasph wrote:Have you give up the wireless feature?
I'm waiting for the BT module to arrive. Should be here in a week or two.
- sordna
- Main keyboard: Kinesis Advantage LF / Dvorak layout
- Main mouse: Logitech M500
Nice keyboard... but I sure hope it's NKRO
Actually, yours has more keys than mine, I have a teensy with the ErgoDox firmware loaded, on a breadboard, without any switch. I do have an led and a piezo buzzer on it though, for a click sound
- teensy_buzzer.jpg (262.64 KiB) Viewed 10194 times
laffindude
- sordna
A short burst (say 10ms) of a sine wave (around 2.4 KHz is my estimate of what my Kinesis does) is what makes a virtual "click" sound. Very useful to add feedback to linear switches, to avoid bottoming out. Kinesis and some old Zenith keyboards have it and it's very nice feature to have. It's like having (linear) Cherry MX blues that you can turn the click on and off whenever you like
You can try this on a linux box to see kind of what it sounds like:
$ sox -n out.wav synth 0.010 sine 2400
$ play out.wav
$ play out.wav
