I don't see any reasons for the asymmetries in current hardware layouts. It's a constant complain ANSI users have about ISO. I also don't even see why the right hand has one pinky column more than the left hand.
So let's gather some opinion. Should the layout be symmetric or do you think you are so righthanded (or left) that it really makes sense?
Would you only make it asymmetric because you're used to it?
Asymmetric hardware layouts...
- Ekaros
- Main keyboard: FILCO MAJESTOUCH 105 MX Brown SW/FI
- Main mouse: Razer
- Favorite switch: MX Clear
Ansi isn't symetric either. The right sift is same distance from home position than left on ISO, not on ANSI... Larger keys in some locations are better, like ISO enter and two key sized backspace, in some smaller ones work better like small left shift.
- Icarium
- Main mouse: opened my eyes
Well, I agree that ANSI isn't symmetric either and I also agree that not all keys have to be the same size but I don't see why that should make the board asymmetric.
I think I left out the general assumption that the software layout isn't supposed to be one of the common shitty ones either. I admit that if you are going to put backspace in the top right corner it might not be such a bad idea to make it huge so you can touch type it anyway.
- Kurk
- DT Pro Member: 0027
Symmetry helps. However, getting rid of the stupid staggering of ordinary keyboard layouts would really make a difference.
- CeeSA
- Main mouse: MM711
- DT Pro Member: 0016
hmm, not easy to say for me. But I tend more to symmetric. I would love a enter key to be one more key to the middle. I always remap caps lock to enter and enjoy it.
In common layouts the right pinky has a lot of more actions than the left. That's unreasonable.
- Icarium
Kurrk: Symmetric staggering is such an important point I kind of want to create a separate poll for it.
CeeSA: So what are you arguments for asymmetric? You said it was hard to decide.
- CeeSA
- Main mouse: MM711
"not so easy" - I said
I voted for symmetric.
If symmetric layout put the caps lock key one more to left, to be symmetric with the right side, than I am more for asymmetric.
Nowadays asymmetric is unreasonable. But this is only one part of having a perfect layout.
- realex
- Main keyboard: Poker 62g MX White
- Main mouse: DA Black Edition
- Favorite switch: various MX
i tend to have my right hand at a slightly "more inward" angle than the left, thus i have worse flexibility reaching right bottom mods. thats why my preferred layout is ansi with the following remaps:
enter on backslash
backslash on capslock
rshift on enter
sounds crippled, i know...
enter on backslash
rshift on enter
