Keyboard won't work after restart
Half-Saint
02 Apr 2013, 11:56
OK, I'm having a weird problem. Both keyboard and mouse work fine when i turn on the computer. However, if I for some reason have to restart Windows, keyboard stops working! Mouse, on the other hand, works fine. The only thing that helps is to unplug the keyboard and plug it back in. That or a complete shut down.
Happens with all my old keyboards on this particular PC regardless of connection type. I'm currently using it with the Blue Cube.
Any ideas?
domoaligato
03 Apr 2013, 00:06
what os? does your pc require a bios update maybe? how old is it? did you build the pc or is it from a OEM?
Half-Saint
03 Apr 2013, 10:54
I'm using the latest BIOS, PC is a self-built Core2Duo system w/ Intel P43 chipset.
The OS is irrelevant because the keyboard goes completely dead after a restart - can't even access BIOS.
03 Apr 2013, 11:05
Half-Saint wrote:I'm using the latest BIOS, PC is a self-built Core2Duo system w/ Intel P43 chipset.
Tried all the motherboard's different USB ports?
I was building a Hackintosh from an Asus mobo recently and driving myself nuts at stage 0 until I figured this out. Nowhere in the docs is it said USB boot only works on the two red ports and none of the other dozen or so USB 2 and 3s. Trial and bloody minded error was all that caught it and got me up and running.
Last time I home built was ten years ago. You only had 2 USB ports then, so of course they worked. But times and chipsets change.
