bhtooefr wrote:IIRC, it depends on whether the board has one or two-piece caps. (I forget if any of the rubber domes got two-piece caps.)
If they're two-piece, the top piece is compatible. The stem part is not compatible, but with some dremel work, can be made to be compatible, as I understand (as it's plastic added to the buckling spring stem design, to depress the rubber dome). This does also mean that buckling spring stems will never work on the rubber dome.
You could put something in a BS stem to make it work on a RD. Not sure if anyone would want to.
Going the other way however, I'd think your dremelling skills would have to be exceptional to get the part where the spring sits inside the stem correct starting from this:
- IBM_RD.png (38.08 KiB) Viewed 3276 times
I doubt they left it correct so you could just cut out that middle piece and get a BS equivalent, the middle part is probably solid right up to the top.
