Question - Can change switches of mechanical keyboard?
- Main keyboard: CMStorm Trigger
- Main mouse: Steelseries Kana
Hi, some places are selling individual switches like Cherry MX Blue, red, green, black and clear. I have a cooler master storm trigger. Possible to buy these individual keys and replace the keys myself? If so, can someone provide a tutorial please? Thanks
Switching out switches always involves soldering at the least. As in de-soldering the current ones then soldering the new guys into place. Pretty time consuming and fiddly, but certainly doable.
I know next to nothing about CM keyboards. Is your one PCB mount or plate mount?
Switches are either PCB mount (no plate) or plate mount, there's a physical difference in the switches which is why both types are sold separately. Plates can make the process harder, from what I've heard.
WhiteFireDragon has some very detailed videos about this kind of modding.
- DT Pro Member: 0011
Practically all new Cherry keyboards these days are plate-mounted. Only Cherry's G80-series (but not all of them) and some enthusiast keyboards (such as the Poker) are PCB-mounted.
- Kurk
- DT Pro Member: 0027
Looks like the Cooler Master Storm Trigger has indeed plate-mounted switches and a LED on each switch. That means de-soldering 4 pins per switch if you want to change them.
http://www.tweaktown.com/reviews/5137/c ... ndex7.html
Yep. I have 55 switches and 200 leds inbound... Some quality time ahead with my Ducky Shine and 15€ Biltema soldering iron... (not)Kurrk wrote:Looks like the Cooler Master Storm Trigger has indeed plate-mounted switches and a LED on each switch. That means de-soldering 4 pins per switch if you want to change them.
- Main keyboard: Ergo Clear MX11800, Ducky 1087XM
- Main mouse: Razer Abyssus
- Favorite switch: Ergo Clear
If you're not up for the soldering and such.. I've seen people that will replace all the switches for you for a reasonable pay
- vivalarevolución
- formerly prdlm2009
- Main keyboard: IBM Beam spring
- Main mouse: Kangaroo
- Favorite switch: beam spring
- DT Pro Member: 0097
Replacing PCB-mount switches is quite easy. I can do it with a modified paper clip. I would link a YouTube video but I'm on my IPhone right now and I'm feeling rather unambitious.
Because he is lazyprdlm2009 wrote:Replacing PCB-mount switches is quite easy. I can do it with a modified paper clip. I would link a YouTube video but I'm on my IPhone right now and I'm feeling rather unambitious.
http://www.youtube.com/watch?v=YaXOuTEHwkw
- vivalarevolución
Yes sir, thank you. The whole copy and paste on an iphone is a bit a hassle.domin8r wrote:Because he is lazyprdlm2009 wrote:Replacing PCB-mount switches is quite easy. I can do it with a modified paper clip. I would link a YouTube video but I'm on my IPhone right now and I'm feeling rather unambitious.
