best pure white ALPS keycaps?
-[°_°]-
09 May 2013, 11:31
What would be the best keyboard to source white keycaps for ALPS switches? I'm looking for a standard(-ish) set (winkeyless would be fine), ANSI or ISO-UK layout. 100% pure white would be perfect but white alpha and grey mods is okay. A bliss if ABS double shot or PBT dyesub. No problem with yellowing (retr0bright FTW!). Any suggestion?
Thanks
Peter
09 May 2013, 13:04
Well, there's Dell :oops: if you can live with laser-engraved caps
But maybe that's what you need them for ?
Northgate Omnikeys have VERY nice caps, but I have never seen one with UK-layout
and the keyboards are pricey collectors-items, so ..
There is also a chance you can find them on old Toshiba-"laptops",
Toshiba T3200sx fex has doubleshots, but I've only seen them in black and a 'Dolch-like' colour-scheme!
Okeg
09 May 2013, 13:38
+1 for the toshiba's or the omnikey's!
Topre Enthusiast
09 May 2013, 14:27
If you can get your hands on an IBM PC Convertible, they have fantastic thick dye-sub caps - better than Topre caps even :)
Layout is a bit weird though.
-[°_°]-
09 May 2013, 14:47
thanks for the suggestions.
the toshiba ones are really nice but I need pure white caps for my next custom (code name whitefox for a reason :) )
all the others seem more light gray than white, but I can definitely live with them. the IBM PC Convertible are lovely.
edit: it seems the ibm convertible can be found at reasonable price, but the arrow keys are not standard size I guess
Soarer
09 May 2013, 17:28
Macally MK96 ?
They are actually white, or very very light grey, rather than ivory as most are. Just lasered though, and a funny font!
-[°_°]-
09 May 2013, 17:38
Soarer wrote:Macally MK96 ?
very nice indeed... it might work but it seems hard to find in EU
09 May 2013, 17:51
I have white keycaps from my Micro Warehouse Power User 105 on my Dell AT101W, with the Dell modifiers. It is a Macintosh keyboard. "Big-ass" Return key, though, which is why I use the Dell modifiers.
tipo33
09 May 2013, 21:03
Old NeXT computer keyboards have amazing doubleshots. I have a set on my Filco Zero.
-[°_°]-
09 May 2013, 23:00
weren't next keyboards black?
tipo33
10 May 2013, 10:24
yes they were, sorry :(
-[°_°]-
10 May 2013, 12:51
So maybe the Apple Extended Keyboard II M3501 is the best source for white ALPS keycaps (and stabs). The spacebar is ABS of course but can be retr0brighted.
Any other ideas?
Daniel
10 May 2013, 13:30
The keycaps for KPT switches are ALPS compatible as well.
There's currently a KPT84 on ebay.de: http://www.ebay.de/itm/321122946648
tipo33
10 May 2013, 15:00
The ESC and F keys on AEK's can't be used. The switches are mounted sideways.
-[°_°]-
10 May 2013, 15:23
tipo33 wrote:The ESC and F keys on AEK's can't be used. The switches are mounted sideways.
thanks for the heads up. I'm building a 65% anyway I wouldn't need the whole F row. ESC would be nice, though
10 May 2013, 23:08
Some dude here has a dead Tactile Pro 2 — those caps are pure, dazzling white, though you do only get nasty scorched plastic lasering. Then of course you would have to make your new keyboard do all the MacRoman extended ASCII characters printed on the keycaps ;-)
10 May 2013, 23:23
Oh but you've got to have all those! ≤≥€«÷¿…æ
-[°_°]-
10 May 2013, 23:53
I've found an Apple Extended Keyboard for few euros but it's IT layout which I'm not very much in love with
REVENGE
11 May 2013, 03:44
Tactile Pro has super white key caps. IMO, the vintage ALPS dyesub caps (ie AT101 or SGI Granite) are better, but not quite as white.
-[°_°]-
11 May 2013, 08:30
tactile pro is definitely white but it's hard to find at a reasonable price
ndp
11 May 2013, 20:56
Some Acer keyboards have ALPS compatible keycaps and should be be really cheap.
Compgeke
12 May 2013, 18:15
PS/2 P70 keyboard has Alps switches and white keycaps, although I that that's one system you could probably sell for more complete than your finished project.
mr_a500
12 May 2013, 19:22
The SGI Granite has nice white keys and the font is nice and crisp (dyesub PBT). The modifiers are dark grey though.
Here it is on an AEK:
-[°_°]-
12 May 2013, 20:21
Lovely! Thanks!
Now... let's see if I can find it somewhere...
mr_a500
12 May 2013, 21:48
Here's an older photo, showing a comparison of original AEK and SGI keycaps on AEK (ignore the lens distortion):
As you can see, many keys didn't fit on the AEK because of "non-standard" switch positioning and stabilizers. (damn you, Apple!)
Sometimes you can find this keyboard very cheap. I got mine - with SGI Indy computer, mouse, cameras, etc. for $20.
12 May 2013, 22:18
The Apple keys also have different profiles than the common "OEM profile". Mixing AEK and Dell or SGI keys is weird.
Gilgam
15 May 2013, 21:50
Same search here for azerty alps keycaps.
Do you know some wiki about the apple keyboards history, and the switches used ?
I may have found some...
Halvar
15 May 2013, 22:23
[shamelessplug]In case someone reading this is himself looking for a black German/ISO ALPS keycaps set for a Matias project, I have a black, supposedy unused Dell 102W lying around that I have no use for. Keycaps are lasered in a thin elegant font. Black ALPS of course.[/shamelessplug]
ndp
15 May 2013, 22:39
I have a faulty SGI keyboard (ansi or iso qwerty) and several AEK keyboards (azerty).
pasph
19 May 2013, 01:33
Tai Hao group buy?
http://deskthority.net/photos-videos-f8 ... t5028.html
"they can do Alps plus custom fonts/colours etc but didn't actually give me the MOQ :)"
