My trusty Model M from 1993 has multiple issues and I'm sending it to Unicomp to be fixed up.
(If you care, it is a 1391401 with a detachable PS/2 cord, blue logo and two-part keycaps. I got her when you could still buy these things on eBay for pennies.)
So how do I ship this thing? What do I use to pack this thing? The Unicomp employee suggested I just take it to the UPS Store and have them do it. But I think it would be better that I did it.
Any ideas?
Sending a Model M for repairs
- Main keyboard: IBM Model M
- Main mouse: Logitech MX400
- tlt
- Main keyboard: Topre Realforce 105UFW
I think bubble wrap is the best packing material. If you need a box with special dimension just make it your self out of cardboard, I have used old moving boxes. Make sure that it hold together, I use glue and a lot of tape
. Make sure that the box is bigger that the item with a margin to take the hit if something pointy hits it. The whole box should be filled with packing materials so that the item does not move around and ends up in a corner or the box. Or let UPS do it, they are probably good at it as its there job
- Main keyboard: Ergo Clear MX11800, Ducky 1087XM
- Main mouse: Razer Abyssus
- Favorite switch: Ergo Clear
It's a Model M, it will be fine.. I've had people just send me one in a big cardboard box without any padding whatsoever and it was still fine
- DT Pro Member: 0049
They are hard to break, but not unbreakable. The caps might come loose, the case might get cracked, ...
Do you really want to leave it to some postal guy to break your keyboard?
Oh definitely not.. If I would send it I would pad it up properly for sure!JBert wrote:![]()
- E TwentyNine
- Main keyboard: AT Model F w/ Tenkeyless mod
- Main mouse: Logitech M310
- Favorite switch: Beam spring
What's wrong with it?
- Main keyboard: IBM Model F AT
- Main mouse: Logitech M310 (Wireless)
I've used UPS to pack and ship keyboards before and never had a problem. However, if you're going to do it yourself, wrap the keyboard in bubble-wrap and pack it snugly in a box using styrofoam packaging peanuts.
- daedalus
- Buckler Of Springs
- Main keyboard: Model M SSK (home) HHKB Pro 2 (work)
- Main mouse: CST Lasertrack, Logitech MX Master
- Favorite switch: Buckling Spring, Beam Spring
- DT Pro Member: 0087
I think the most important thing is to ensure that the keys do not get stuck in the pressed down position for extended periods of time. Other than that, bubble wrap to ensure the case doesn't get damaged.
