I've seen crystals larger than this ! !
Peter
21 Jun 2013, 19:13
How do you like this,
a USD54.99 UFD-sized computer with :
OS :
Android 4.2 UPDATED! (You can also install Linux to it !!)
CPU :
RockChip RK3066 DUALCORE - Cortex A9
Memory :
1GB DDR3
Storage :
8GB NAND Flash
Graphical processor :
MALI 400
Network :
Wireless 802.11b/g/n
Expand Memory :
Micro TF Up to 32GB
IO/Ports :
2 x Micro USB, 1 x USB2.0, 1 x HDMI, 1 x MicroSD
Keyboard :
Z2C Supports virtual keyboard, 2.4G wireless keyboard, fly mouse, another USB keyboards
Audio :
AAC, AAC+, eAAC+, AMR-NB, AMR-WB, QCP, MP3, WMA, WAV, MIDI, M4A
Video :
M-JPEG, MPEG-1, MPEG-2, MPEG-4, H.263, H.264, VC-1, DivX, Xvid, RealVideo, VP6, Sorenson Spark
Android APP :
Google Search / Email Gmail / Video Player / Audio Player / Alarm / Clock / Calculator / Calendar / ES file / Explorer / ES Task Manager / Google Maps / Google Play / NC Manager / PDF Reader / Photo Browser
HDMI :
1080P&2160P
Power Input :
Powered by the USB port
Accessories :
Power Adaptor, HDMI Cable, USB Cable, User Manual
Unit Size :
8.0 x 3.8 x 1.4cm
Total weight :
0.35kg
http://www.asiapads.com/en/android-4-2- ... -2318.html
21 Jun 2013, 19:19
Someone's drugged the Android logo!
Peter
21 Jun 2013, 19:37
Muirium wrote:Someone's drugged the Android logo!
Yeah, my guess is that M$ slipped 'droid' a downer or two !
Seriously :
There is plenty of space inside a G80-1501 for this device !!
To bad it doesn't have PS/2-port ...
21 Jun 2013, 19:48
I see where you're going with this…
The entire software library of any (every!) microcomputer could fit snug inside.
Peter
21 Jun 2013, 20:53
I was thinking something like this :
Just without the lunch-box form-factor ...
Maybe there are even better micro-computers available ?
ATA-compliant HDD-controller, PCIe and PS/2-port would be great !
Jmneuv
21 Jun 2013, 21:43
Wow, had forgotten about these. Looks like theres some good competition products also though.
21 Jun 2013, 23:42
This with a mobilephone antenna and a display would make a nice smartphone.
:o
Halvar
22 Jun 2013, 00:47
Wow, they can make a computer that's equaivalent to a smartphone as small as ... a smartphone!
@7bit: only when you're near a power outlet... ;-)
22 Jun 2013, 08:27
Halvar wrote:@7bit: only when you're near a power outlet... ;-)
Should be no problem. There are some poweroutlets in many cities (for charging electric cars) so I could plug it in and make a call.
:cool:
Return to “Off-topic”
