There seems to be a problem with red prefix, it's shows up too often, the first time I viewed the thread in question (http://deskthority.net/viewtopic.php?f=17&t=60) it showed up only two times, but when I went back to snap a picture, it had gotten to three. The same doesn't happen when the thread has black prefix (maybe that is set manually by the user in the subject, I don't know.)
Prefix problem
- sixty
- Gasbag Guru
- Main keyboard: DKSaver
- Favorite switch: Cherry MX Black
- DT Pro Member: 0060
Hm. We had this happening yesterday in testing and were unable to find the cause and reproduce it. Thought it was fixed... guess not! I'll look into fixing it or disable prefixes until we find a solution.
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
sixty wrote:Hm. We had this happening yesterday in testing and were unable to find the cause and reproduce it. Thought it was fixed... guess not! I'll look into fixing it or disable prefixes until we find a solution.
TEST!
- sixty_spacebar.png (1.37 KiB) Viewed 3836 times
- mail_form_dtn_001.png (42.07 KiB) Viewed 3837 times
- 7bit
sixty wrote:Each reply spawns one?
Edit: nope.
No, but I know for sure now!
It is is very simple:
There is a 1:1 correspondence between every attached image and the [Bug]-s in the title!
- sixty.png (8.02 KiB) Viewed 3833 times
- 7bit
Seems to be fixed.7bit wrote:sixty wrote:Each reply spawns one?
Edit: nope.
Let me guess: an un-initialized variable, right?
