Opinions about old BTC 5339R keyboard
Laser
emacs -nw
01 Nov 2013, 13:52
Any detailed info abut a keyboard similar with this one?
http://www.ebay.com/itm/Leading-Edge-AT ... 0857615103
Topre Enthusiast
01 Nov 2013, 14:08
Laser
emacs -nw
01 Nov 2013, 14:12
Yes, thanks - That's how i got to the ebay link / image in the first place :) What i mean is, *extra* information.
EDIT: Actually, by searching for "BTC foam and foil", i also got to this link:
http://deskthority.net/wiki/BTC_5339R-0
01 Nov 2013, 23:12
Hm, I missed Chimborazo posting that. Thanks for the heads up!
IvanIvanovich
03 Nov 2013, 16:51
I've had a few of these. Generally I think they feel not too nice. Even on NIB sample, I thought they were rather mushy feeling. On used sample they are truly bad when the foam has become compressed and degraded. The ones with doubleshots the keycaps were pretty nice. Profile is nearly identical to Signature Plastic DCS but about twice as thick.
The best BTC keyboards are those that came right after foam and foil as far as I can tell. They are rubber domes but have each key as individual with a (I think) type of carbon contact on a real PCB not membrane with same type MX keycap compatible sliders as foam and foils. Or in otherwords they are made just like the foam and foil in every regard but switch to dome instead. Those are quite similar feeling to topre, more so than any other rubberdomes I have tried anyway.
Laser
emacs -nw
04 Nov 2013, 13:45
Thanks for the info! What i've got has no doubleshot keycaps and indeed doesn't feel nice to type. The keys are also quite yellowed, so i don't know if i can recondition them. Perhaps i could put the springs to some use.
04 Nov 2013, 21:45
Flatten them and make a slinky for your gerbil?
Laser
emacs -nw
28 Feb 2014, 19:31
(thread necromancer at work)
A question (i don't have a topre board) - how far are these from being a topre-to-cherry-mx keycaps adapter solution?
The plastic stem looks similar to: http://deskthority.net/w/images/2/22/BT ... sembly.jpg
