Nichrome plate - yes or no?
wobbles
16 Dec 2013, 17:40
So long story short, i was messing around in my garage and found some nichrome plates. It looks like 1mm thick. Now, the question is - could i lasercut a plate with these? I would try it out if i could, but lasercutting is pretty expensive here and on top of that i have to drive to another city for it.
After poking it with some random stuff from the garage i can at least say that it's pretty stiff but i can flex it easily. I don't understand either tbh.
A google search didn't give me much results.
Broadmonkey
Fancy Rank
16 Dec 2013, 17:54
If you want to use it as a plate for cherry MX switches, it needs to be 1.5 mm thick for the best result. If it's expensive to cut. I would just pay the additional for a thicker plate.
wobbles
16 Dec 2013, 18:12
Will actually measure them once i come back. If it's not 1.5 then i guess im just gonna go with aluminum. They did look like 1mm though.
