Wheelwriter 5 (ISO Enter, boltmodded).
sethstorm
04 Feb 2014, 14:03
About
One of the more odd M variants, Wheelwriter keyboards are found exclusively on typewriters. Stock ones usually follow an M-like physical layout while having a non-M electrical layout. They also seem to have the same quirk of being able to substitute the reverse-L enter for an ISO enter.
While the SSK and other small form-factor buckling spring boards are "physically complete", one will have to harvest parts from the corresponding Wheelwriter. This is due to the Wheelwriter's keyboard being integrated with the typewriter as a part of a whole unit. Despite this shortcoming, Wheelwriter keyboards can be made into viable space-saving keyboards.
Why not attach it to an M controller?:
While it has a similar layout as far as having two M-like strips, the layout does not map to an M in any meaningful way. However, custom controllers like Soarer's can handle the layout - the only difficulty is sourcing a proper connector without harvesting an M(or two) for it. They do not interface directly with breadboards, but will fit snugly in flat sockets.
Once that is out the way, the keyboard can be attached.
Attaching the keyboard
This keyboard has the following mapping and layout:
(Note: Due to the lack of Wheelwriter keycaps, this one uses a mix of Terminal M, M, and M13 caps. I would be interested in finding a proper set, though.)
Strobe pins, 13 pin strip (1 = leftmost pin as pictured above)
1 : D0
2 : D1
3 : D2
4 : D3
5 : D4
6 : C0
7 : C1
8 : C2
9 : C3
10: C4
11: C5
12: C6
13: C7
Sense pins, 8 pin strip (1 = left most pin)
1: F0
2: F1
3: F2
4: F3
5: F4
6: F5
7: F6
8: F7
Block to use for Soarer's Controller:
# Wheelwriter 5 Matrix (ISO Enter)
# A sane, yet minimalist layout.
# Layout Notes:
# Layout mostly follows AT(Ctrl between Tab/Left Shift, Caps Lock below Right Shift) aside from ISO Enter/F11/F12.
# Top two keys in the 5-key vertical block are PgUp/PgDn respectively.
# Bottom two keys in the 5-key vertical block are F11/F12 respectively.
# The middle key in the 5-key vertical block on the right can be used as follows:
# [Modifier]-WASD : Cursor keys (Up/Left/Down/Right)
# [Modifier]-[Number key] : Equivalent numpad key
# [Modifier]-[Backspace] : Del (for those wishing to perform Ctrl-Alt-Del, use Ctrl-Alt-Modifier-Backspace)
# [Modifier]-[PgDn] : Left Win/GUI key
# [Modifier]-[`] : Escape key
matrix
	scanrate 1
	debounce 5
	blocking 0
	sense 			PF0		PF1		PF2		PF3 		PF4		PF5		PF6			PF7
	strobe	PD0		UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED		LALT
	strobe	PD1		F10		F7		F1		F3		F4		F5		F11			SPACE
	strobe	PD2		F9		F8		F2		UNASSIGNED	TAB		F6		LCTRL			CAPS_LOCK
	strobe	PD3		UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED	UNASSIGNED		LSHIFT
	strobe	PD4		UNASSIGNED	A		BACK_QUOTE	1		Q		UNASSIGNED	Z		8
	strobe	PC0		UNASSIGNED	S		UNASSIGNED	2		W		UNASSIGNED	X		I
	strobe	PC1		UNASSIGNED	D		UNASSIGNED	3		E		UNASSIGNED	C		K
	strobe	PC2		G		F		5		4		R		T		V		B
	strobe	PC3		H		J		6		7		U		Y		M		N
	strobe	PC4		UNASSIGNED	K		EQUAL_SIGN	8		I		RIGHT_BRACE	COMMA		I
	strobe	PC5		UNASSIGNED	L		3		9		O		5		PERIOD		6
	strobe	PC6		QUOTE		SEMICOLON	MINUS		0		P		LEFT_BRACE	BACKSLASH	SLASH
	strobe	PC7		UNASSIGNED	FN2		BACKSPACE	PAGE_UP		PAGE_DOWN	6		ENTER		F12
end
macroblock
endblock
layerblock
	FN2 2
endblock
remapblock
	layer 2
	W UP
	A LEFT
	S DOWN
	D RIGHT
	BACKSPACE DELETE
	BACK_QUOTE ESC
	PAGE_DOWN LGUI
	1	PAD_1
	2	PAD_2
	3	PAD_3
	4	PAD_4
	5	PAD_5
	6	PAD_6
	7	PAD_7
	8	PAD_8
	9	PAD_9
	0	PAD_0
endblock
To Do:
Source Wheelwriter 5 keys, and keyboard frame to assemble as a whole unit.
Thanks go to:
Phoenix from the other keyboard forum, for sending me the parts for a Wheelwriter 5 (and a matrix + plate from a Wheelwriter 3500).
Redmaus
Gotta start somewhere
19 Feb 2015, 01:03
Wow, this looks really cool.
One question though, are the switches any different in sound or feel to regular model M switches?
Haroxicos
19 Dec 2016, 22:17
Your guide was a great help!
I've build mine. I changed a bit your config and i'm now typing with it!
I love those caps.
Further improvements will be to cut off the top case, like some M to ssk mods and silence it a bit with some small bit of strings in the spring...
Thank you!
http://imgur.com/a/MoTah
micrex22
21 Dec 2016, 09:46
Haroxicos wrote: Your guide was a great help!
I love those caps.
Thank you!
Your wheelwriter still has some of the LEDs, you should hook those up. Soarer's converter has pinouts for LED outputs.
One could also go the space unsaving route and keep the whole typewriter intact and plop it on their desk as a "keyboard".
Haroxicos
21 Dec 2016, 12:18
The LEDs are not a priority because i barely use Caps Lock.
I never use scroll lock and i can't use num lock.
However with the project to cut off the plastic top plate, i'll see if i can make a good integration of one LED.
BTW the "huge & massive" Wheelwriter i found in trash was damaged, broken and dirty as hell.
http://imgur.com/a/xAAm6
I have no plan to make a restauration of it.
I'll go for a compact KB.
