Wireless ErgoDox ???
- des_illacom
- Main keyboard: ErgoDox
- Main mouse: Microsoft Explorer 3.0
- Favorite switch: Cherry MX Black
Hey guys,
Just like the 'subject' says, wireless ErgoDox... is it even possible? I'm one of many waiting for MD drop to ship out my kit, In the mean time I've been kinda kicking around the idea of hacking a wireless connection together for ED... Been looking at Arduino / ExBee / Wifi ... Reading up on arduino forums, thought i'd share some links , and see if anyone can shed some light on if/how this can be accomplished...
WHY: I am hoping to relocate my PC tower to the closet and get rid of as many wires as possible. The 'master' plan is to have Wacom / ErgoDox / 24" Monitors all "detached" from the tower... But I figure I should start by trying to get ED working first...
HOW: (see attached diagram)
method A (usb over IP(wifi))... ED (teensy) would need connect to an Arduino UNO via USB host shield and send user inputs, from there the signal would need to be passed over to the Wifi shield for broadcasting... The signal would need to be picked up by Router and routed to PC , then "somehow" interpreted as a keystroke(s)
method B (usb over XBEE)...ED (teensy) would need connect to an Arduino UNO via USB host shield and send user inputs, from there the signal would need to be passed over to the XBee Shield for broadcasting... The signal would need to be picked up by another XBEE module that would be connected to the PC through XBee Explorer USB , then it would also "somehow" would be interpreted as a keystroke(s)...
In both methods, ErgoDox would need to be powered through the Arduino...
I'm going to keep researching this idea, so If anyone has suggestions or links to existing solutions that would be great...
- ARDUINO_ERGODOX_DIAGRAM_V001.jpg (52.93 KiB) Viewed 11156 times
- des_illacom
A cool idea was introduced on GeekHack
1.Desktop Computer > running 'Synergy - Server'(any OS)
connected by LAN cable to Network Router(BEST DAMN ROUTER EVER MADE
2.Raspberry Pi > running 'Synergy - Client'(Linux OS)
drawing power from USB power supply
connected by USB Wifi Module to the network
3.ErgoDox & Wacom Intous 5 & Whatever else HID device > connected to the Raspberry Pi through a USB HUB
I guess then the question would be, what are the limitations of Synergy:
Is there noticeable lag for HID input, making connection of a Wacom Tablet useless?
Does the Raspberry Pi need to be connected to a monitor to be compatible with Synergy?
Is there a light enough easily implementable battery power solution that would juice the Pi & ErgoDox & Wacom & USB HUB (possibly external monitor)?
If anyone else has any input on this , it would really help...
If this sounds like a viable theory to you guys, I'm going to order up the parts and post a complete breakdown on implementing this setup at home...
This is what the diagram looks like so far:
I'm following this. I use Teensies with my keyboards extensively (as a controller or as a converter) and many of my keyboards (Model Ms especially) have lots of empty space available for a big heavy battery, too. That's a useful way around the real challenge of wireless peripheral design: power efficiency.
Filco's Minila Air can run on a few AAs for months. Its Bluetooth module is separate from its controller, I think. There are definitely several ways worth exploring.
Some links:
http://deskthority.net/workshop-f7/stee ... =bluetooth
http://handheldsci.com/kb
Some links:
- czarek
- Main keyboard: HHKB Pro 2
- Main mouse: Magic Trackpad 2
- Favorite switch: I have no favourite - I love them all!
I was thinking about using this with ErgoDox:
http://www.adafruit.com/products/1535
I would really like bluetooth as it could allow use ErgoDox with iPad.
- des_illacom
Very cool, I think I'm going to add it to my order of parts, would like to have a BT option
nice find , thank you...
Bad news:
http://deskthority.net/post145216.html#p145216
And good news:
https://www.sparkfun.com/products/10823
And good news:
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
I have a RN42hid... I can't say it's that of a good news though
it's not different from other HID bt modules, and they all have the same issues we all know.
this https://www.sparkfun.com/products/11378 is maybe more interesting, having the power module integrated
Hmm. Potentially! Having browsed through all their links, I can't figure out what it actually hooks up to. (Engineers: use diagrams, please!) So what are we talking about: this plus a Teensy / some other controller?
I suspect that the best power efficiency comes from a single component answer, of course. But we can always through battery power at inefficiency and see what we come up with!
Cool, I was hoping it was something simple. (Pure serial, right?)
Next question is how much current does a Teensy draw while scanning a matrix with zero keys pressed? Because that's the keyboard's base state, even while typing.
- matt3o
- -[°_°]-
a Teensy draws about 7 mA at 3.3V/8MHz (you are going wireless so you most likely want to downvolt and downclock it).
but you could make an algorithm that slows down the scanning over time of inactivity. so the first stroke will have (say) 100ms delay and the others virtually none.
Exactly. How much is the matrix scanning the power hog compared to just the Teensy up and running by itself? (I'm a noob and don't even know if Teensies can be told to sleep for a given time, etc.)
I wouldn't mind having a wake up key to press, for instance, after an hour's absence. That could stretch the lifespan greatly.
kile
- Main keyboard: Steelseries 7G Wireless
- Main mouse: Razer DeathAdder Leftie
- Favorite switch: Cherry MX Green
Actually, I think this is possible with the small nRF24LE1 board I used for the PJE's OneHand wireless. It looks like the nRF board is just large enough to fit between the two rows of pins for the Teensy. So it should be possible to make a PCB that will plug into the place for the Teensy and accept the nRF board. Kind of like an adapter. As long as the 15 available IO pins of the nRF are enough for the matrix, I think this should work.
- pietergen
- Main keyboard: none yet
- Main mouse: none - keyboard shortcuts
Sorry to kick this one up.... I am thinking about a wireless "microdox"/redTilt (hi Suka !) build, so:
- two halves, half A communicating with half B;
- half B containing the 'brain' that communicates with the computer;
- I'd like to have trackpoints in both halves. Like two of these (no longer in production, but can still be found online ). Setup: one for mousing, one for scrolling; or one as a fast, mouse and one as a slow, precise mouse
- in the ideal case, I'd like to bring only 3 pieces with me: half A, half B, and a USB receiver that I stick in the PC. The receiver is in that case for the keyboard and "mouse" (read: both trackpoints). only 3 pieces
- encryption is not needed for the "mouse", is maybe needed for the communication between the keyboard halves (I'm not sure actually) but is absolutely needed for the keyboard communication with the PC. I don't want to transmit my keystokes, open for everybody to read !
Would this scheme be possible with three nRF24LE1 boards? 1 in half A, 1 in half B and one in a USB receiver... Thoughts ? Thanks !
- pietergen
OK, the simpeler solution is: wireless communication between the halves, but a wired connection from one half to the PC. Question remains:
will I be able to transfer keyboard AND "mouse" data through that one wire?
Is a Teensy capable of processing mouse events?
And will a pc understand a combined keyboard/mouse data stream ?
(for completeness: I use both Linux and Windows machines, I am most worried about the Windows ones, I have learned that they are the 'dumbest')
