Aquarius CSK-2102 - White ALPS
Nuum
04 Mar 2014, 16:45
Hello,
I'm kinda new here, I was lurking and reading quietly for quite a while now but I never introduced my self. So let's do that first, before I show you the keyboard from the title.
I'm currently studying Engineering in Germany. About a year ago I bought my first mechanical keyboard, a Tesoro Durandal G1N with MX Brown, which I'm still using with thick Cherry PBT dyesubs. I know that it's kind of a cheap keyboard but I really like it. Furthermore I own a G80-1000 HAD and another ALPS keyboard, which I will show you in a while.
But now to the keyboard, which I meantioned in the title. It's a German ISO Aquarius CSK-2012 with (complicated) clicky white ALPS and a Dolch-like color scheme. The switches feel amazing to me, much better than MX Blue.
This is, how the keyboard looks, I cleaned it quite a bit but it's still a little bit dirty and yellowed.
front 2.JPG (985.39 KiB) Viewed 6484 times
Naked 2.JPG (995.55 KiB) Viewed 6484 times
It also has a nice cable channel, so you can have your cable anywhere you want. It has a DIN plug, which has the same pins as PS/2 but is much bigger. The housing reminds me of a mix of a G80-1000 case and a Focus FK-2002 case. There ist no manufacturing date on any part of the keyboard, perhaps it is hidden under the metal plate.
Here you can see, that the edges of the keycaps are yellowed quite a bit:
6key 2.JPG (955.83 KiB) Viewed 6484 times
The profile is kinda standard:
keycap profile.JPG (989.22 KiB) Viewed 6484 times
keycaps rear.JPG (987.9 KiB) Viewed 6484 times
The caps could be thicker, but they fell quite nice. I threw them into water and they sank immediately, so they should be PBT, but they seem lasered with infill or pad-printed. The Spacebar has another ALPS mount to the right of the normal mount and a cross-mount, which does not fit on Cherry MX on the left.
Unfortunately some keys are supershiny but the lettering is as clear as on the other keycaps, so I don't really know how the lettering was made. Maybe some of you know more about that.
The caps have a nice curve on the sides, while the front and back are straight:
PCB:
The PCB has an Intel controller, but it doesn't say, who made the keyboard.
Costar-like stabilizers:
space bar stab.JPG (974.77 KiB) Viewed 6484 times
stab insert.JPG (977.69 KiB) Viewed 6484 times
It has an AT-XT-Switch:
The switches should be complicated clicky white alps:
White ALPS 2.JPG (983.36 KiB) Viewed 6484 times
The photo colors are not quite right, they are a little bit too blue but I'm not very good at correcting colors.
Does anybody know, if retrobright would work on grey yellowed keycaps too or wether it would bleach them?
Thanks for watching my first keyboard thread! Feel free to use these pictures, but please refer to this thread.
Nuum
BlueBär
04 Mar 2014, 17:07
Very nice looking board. I think retrobright would bleach them.
sean4star
04 Mar 2014, 17:23
I agree about those complicated whites. Much smoother with a pleasant actuation and click. It makes the MX blues seem harsh by comparison.
04 Mar 2014, 17:41
Really nice board. I also agree about complicated white ALPS. Much more pleasant than Cherry "clicky" switches.
04 Mar 2014, 17:44
Intel controller chips were very common, from what I can tell. Certainly, I've seen a few. Even my 1984 Macintosh keyboard has one! With some Intel copyright date from the seventies on it, as usual.
Alps are pretty distinctive aren't they? I'm toying with the idea of a Matias switch custom keyboard now I have caps to spare.
Nuum
04 Mar 2014, 17:54
I would like to build a custom Alps keyboard, too! I think, I've seen jdcarpe planning a Alps TKL groupbuy over at geekhack, let's see, how that goes. I'd love to have a TKL or even smaller Alps-based keyboard.
I don't know how Matias switches feel, they should be technically the same as simplified Alps, shouldn't they? I really like the feel of those complicated ones and i've heard the simplified are not quite as good as these. But I've never tried them for myself.
This keyboard has quite decent rollover, especially on the WASD area you can press all necessary switches for FPS-Gaming at once. But I'd like a keyboard with n-key-rollover, just for the sake of having it.
Kurk
04 Mar 2014, 18:26
From a distance I would say your caps are pad-printed ABS.
The caps remind me of the portable thing I've found a year ago.
http://deskthority.net/photos-videos-f8 ... t5298.html
Nuum
04 Mar 2014, 20:11
Yeah, they look pad-printed. But they must be laquered, so that the lettering on the very shiny caps remains intact. Also they sink in water, but maybe that test is not reliable.
nourathar
04 Mar 2014, 21:31
nice-looking keyboard and caps ! is that plate plastic or metal ?
Nuum
04 Mar 2014, 21:37
It's metall, approx. 1mm thick.
Topre Enthusiast
04 Mar 2014, 22:12
Nice board! Regarding the retrobright, it seems to be a bit of a misconception that it works by bleaching the plastic, but it doesn't, otherwise restoring items like the grey Atari 130XE wouldn't be possible.
The bleaching/bloom issue happens when you use a stronger Hydrogen Peroxide or you add too much Oxiclean. For keycaps, I wouldn't even bother with the Oxiclean -- just soak them in a jar with diluted H2O2 out in the sun. If you're worried about bleaching the caps, try it with a single one first maybe around the bottom of the cap only so worst case scenario it will be hidden on the keyboard. I think it will be fine though.
Oh an your keycaps don't really look too bad yet anyway :) I would hold off for a while!
04 Mar 2014, 23:23
Nuum wrote:Costar-like stabilizers: …
Better: Costar stabilisers.
The first three or five (and in vintage keyboards it will be three) letters of the FCC ID represent the "grantee", the company to whom the FCC ID has been granted. Pop that in here:
http://transition.fcc.gov/oet/ea/fccid/
GS2 is Costar.
terrpn
05 Mar 2014, 18:51
nice-- congrats on a great looking board :D
Halvar
06 Mar 2014, 16:15
A very good-looking Alps board, and the legend print looks much prettier and more durable than on my black Dell AT-102. May I ask how you found this? Never heard of an "Aquarius" brand before.
Nuum
06 Mar 2014, 18:59
Basically it was pure luck, I found this on Ebay a while ago. It looked rather interesting and the description said, that the keys "click" on activation. Since it didn't look like a MX board to me, I was curious and bought it. Actually I would have bought it as MX version, too! It wasn't that expensive. Later on, just after I got it delivered, I searched for it on the web and someone on geekhack has found one of them, too.
I searched for the FCC ID (thanks for the tip, Daniel!) and ther is one with the exact same but with 2084 at the end, so that leads me to think, that there are some with a layout similar to the Keycool 84 out there (FCC ID: GS23TYDGK-2084N). And of course an ANSI version.
