Alphameric foam and foil
29 Apr 2014, 01:06
Nick from Devlin was so kind as to send me a little goodie back of Alphameric switches. What's interesting is that they're not the switches I thought they'd be. The ones Devlin still make as spares (after acquiring the keyboard division of Devlin) are the foam and foil version.
Goodie bag:
Goodie bag 2.jpg (382.25 KiB) Viewed 2230 times
Goodie bag 1.jpg (323.13 KiB) Viewed 2230 times
Switches:
Alphameric foam and foil.jpg (297.92 KiB) Viewed 2230 times
Even before I got home, I'd already broken one of the springs :)))
It makes me laugh just looking at it. I break things.
No time left to post anything to the wiki — I also took the time to do the SMK clones that padath sent me. Despite my rubbish camera skills I even got some really nice pics of the hard-to-see "logo" on the bottom. And spent some time trying to get one back together before realising I had the terminals in back to front … I hate SMK switches and their ilk, they're such a headache to reassemble, though I've found a way to get the vintage ones together most of the time, at least.
And thanks to the mess that is modern IT, my camera's hit image 9999 and rolled over into a new directory, with filenames that are duplicates of the ones I've already got. (I always rename the existing ones back a letter, e.g. IMGP → IMGO, IMGO → IMGN etc so that they're always in name order. Why I need a frigging "P" in the name instead of a fifth digit, I will never know. In fact, why not just have a whole eight digits. It's not like I haven't taken 30,000+ images on this one camera already ...)
Compgeke
29 Apr 2014, 01:29
Any chance are the foam pads the same size as the Keytronic foam pads? If so it would be interesting to know if they do runs of the pads only as the vintage computer people would love 'em to fix the old keyboards without having to hack something together.
29 Apr 2014, 02:07
I only have this photo for comparison:
http://deskthority.net/wiki/File:KT_foa ... ernals.jpg
For that particular Key Tronic, the slider guide unit (the part that snaps into the plate and holds the slider) is a lot taller, as is the foam pad.
For Alphameric switches: the foam pad is ca. 10.6 mm diameter and ca. 3.5 mm thick. The slider is ca. 10.1 mm tall above the pad mounting platform, which is ca. 1 mm thick. The slider plus foam pad totals ca. 14.5 mm. The slider itself is 8 mm diameter. The slider's width where it runs along the guide unit, is 16.4 mm.
They look a lot like Key Tronic but I don't know that any dimensions match.
mr_a500
29 Apr 2014, 13:59
Compgeke wrote:My any chance are the foam pads the same size as the Keytronic foam pads? If so it would be interesting to know if they do runs of the pads only as the vintage computer people would love 'em to fix the old keyboards without having to hack something together.
Yes, I would definitely like to order some new pads. I bought an entire NOS vintage Keytronic keyboard just in case I need some new pads for my Victor 9000.
29 Apr 2014, 19:40
I'll check what options are available.
30 Apr 2014, 01:03
Good news: foam pads with foil attached would be £0.35 each to forum members.
Bad news: manufacturer MOQ is 90,000, so unless there's a huge rush, the only size available is Alphameric foam and foil.
17 May 2014, 23:40
Compgeke wrote:Any chance are the foam pads the same size as the Keytronic foam pads? If so it would be interesting to know if they do runs of the pads only as the vintage computer people would love 'em to fix the old keyboards without having to hack something together.
Here are all the key slider dimensions:
Alphameric foam and foil -- slider dimensions.png (92.06 KiB) Viewed 2066 times
How do these compare with Key Tronic?
