What is the best quality feel keyswitch for a thin keyboard?
olafweller
08 Jun 2014, 10:25
Hey guys,
I am a product designer from the Netherlands, and I am currently designing a new keyboard
I want the keyboard to be as thin as possible and I want the keys to feel amazing when you type on them! (and I want to use mechanical, not capacitive)
I found a manufacturer in Germany who can produce the keyboards for me and he uses Cherry ML switches. However, I saw a video of a guy who tried the ML switches and didn't like them at all! https://www.youtube.com/watch?v=d5nScpSnec4
I was also thinking of the Apple scissor switch keyswitches but this guy also says they are not that "tactile" https://www.youtube.com/watch?v=r17balD1nJc
So now I am wondering: what is the best switch for me to use? That is why I want to ask you, the experts, what you would advice me. I want the total key (switch + cap) to be as thin and have I want to have a high quality feeling.
What would be your number one choice?
08 Jun 2014, 13:05
The best scissor switches I've used were those in a Dell Latitude E4310, which were exceptional. There is no guarantee that Dell didn't use multiple suppliers though. Scissor switches can be superb if you find a supplier interested in quality, who is competent in terms of design and specification, and is committed to maintaining a consistent product batch after batch. That's going to be the hard part, because scissor switches are not classed as a quality product.
It would be useful to understand more about the product. Specifically, how is it going to be used, and what is the acceptable range of thicknesses? Are you aiming for a thin look (like the Cherry G80-3850) or do you need the keyboard to physically be so many mm thick due to actual size constraints?
Quality doesn't stop at the switches. You have to give the legends serious consideration. Pad printing is subject to wear. Laser etching (white on black) is subject to staining. Dye sublimation is nice so long as you're using light coloured caps. Does it matter to you that the legends rub off or turn black? (Laser etching turns black readily — it's a lot worse than pad printing for durability in my experience.) This is an issue for us here, because we are not able to fit aftermarket keycaps to anything besides Cherry MX-compatible switches (and hopefully, soon, Alps-compatible switches).
08 Jun 2014, 14:43
Don't worry too much about one guy reacting badly to a switch. Every switch, no matter how great, has its haters. They're all down to personal taste, really. Which is one of the Cherry MX line's greatest strengths: so many different flavours.
I'm not sure how far you could go with thinness as the overriding design goal. All the switches we keyboard afficionados like are way too deep to fit into something like Apple's modern designs. And if you sacrifice typing feel, you're stuck with Logitech etc. in a world of mediocrity we don't spend much attention to.
Perhaps the better direction is to take a solid switch (MX is by far the easiest, especially for compatibility and sourcing high end caps, which we crave as much as feel) and designing an elegant, distinctive case around that one constraint. It won't be as svelte as modern chicklet boards, but it won't suck as desperately either.
08 Jun 2014, 15:36
I think that things to look for in a scissor switch are stability (opposite to rattle), reasonable amount of key travel and tactility.
Scissor switches can indeed be very stable, much more so than most other switches and the scissor mechanism means that they don't bind on off-centre key presses. Laptop keyboards often sacrifice key travel for thinness but desktop keyboards are often good. Tactility is about the quality of the silicone dome that needs to be pressed.
Scissor switches are not mushy on the bottom like regular rubber domes, but because of the silicone sheet of domes, the landing is distinct but soft and I think that is a good thing.
Unfortunately, scissor switch keyboards are not often very durable. I have had a silicone dome wear out and it is often that keycaps are broken so they can't be reattached. If the keycaps are printed with UV-coating, the switch will wear down easier than the printing on the keycap.
The scissor switch keyboard that felt best for me was a Logitech DiNovo Edge, which is one of several that have their "PerfectStroke" switches. These have high key travel for a scissor switch at 3.2 mm, but it doesn't need to be that high to feel good in my opinion. These are also stable, tactile and have "regular"-shaped keycaps (as opposed to chiclet). The space bar and other keys on the bottom row being relatively high and convex also made a difference.
Otherwise, the most popular scissor-switch keyboards based on feel seem to be the Logitech UltraX and the keyboards in some older ThinkPad's (before chiclet) but it is known that IBM/Lenovo used several suppliers so it is difficult to tell which version people refer to.
The Apple Aluminium desktop keyboards are light and tactile, and well liked for it. The guy in the video is probably referring to them being too light for his taste. BTW, the key travel on the Apple is 1.9 mm - personally I would like a fraction of a mm more.
I am not a fan of Cherry ML. Compared to scissor switches, it binds on off-centre key presses, it lands hard and it is has a scratchy feel. The binding-issue is why most keys larger than 1×1 are "hat caps" -- all other keys larger than 1×1 have an additional stabilising wire. I suspect that the scratchiness gets worse with exposure to dust.
BTW, you could consider designing your keyboard with a slight curved_backplane. That also makes a difference in feel, but I would say that it is a lot about personal taste. It is not objectively better.
Hypersphere
08 Jun 2014, 16:57
There are the new magnetic levitation switches to consider if you want the ultimate in thinness.
Regarding more mainstream switches that are currently in use, I would like to see new keyboards that do not use Cherry mx switches and certainly not Cherry ml switches. In particular, I would like to see new keyboards that use the Matias tactile/cicky and/or Matias silent switch.
08 Jun 2014, 18:16
Matias switches are larger than MX, unfortunately. And you're in for a world of hurt for caps.
But at least they actually exist and you can buy them. Unlike certain maglev concepts!
RC-1140
08 Jun 2014, 18:48
Findecanor wrote:I am not a fan of Cherry ML. Compared to scissor switches, it binds on off-centre key presses, it lands hard and it is has a scratchy feel. The binding-issue is why most keys larger than 1×1 are "hat caps" -- all other keys larger than 1×1 have an additional stabilising wire. I suspect that the scratchiness gets worse with exposure to dust.
Granted, but I still enjoy ML switches. I don't know why, but I prefer them over most scissor switches. Yes, they do bind if you don't hit them centered. But that's just a matter of getting used to it. I've used a G84-4100 for about half a year every day. It tought me to type "cleanly", and after a short time the binding wasn't an issue anymore. But yes, it is a problem with ML switches, and I doubt most people want to buy a keyboard which requires you to type well.
CeeSA
08 Jun 2014, 19:53
For a scissor switch I like it most at this board:
http://www.activekeyboards.eu/Compact-K ... anguage=en
They feel very different than other scissor switches for example the thin apple keyboards.
Feels like heavy duty and have a loud sound and good feedback.
Topre Enthusiast
08 Jun 2014, 20:05
I wonder what ever happened to the Synaptics capacitive switch? It was teased a few years ago but I haven't seen or heard of it since.
08 Jun 2014, 20:18
Most things that get announced either never ship, or fail quickly when they do. That's why I don't have high hopes for the maglev vapourware pony switch. When it's out, getting reviewed, and earning its place in the keyboard world, I will change my mind. But the odds are anyone's guess.
vivalarevolución
formerly prdlm2009
08 Jun 2014, 20:44
Would it be possible to make a low-profile Topre switch? That would be an interesting option. Not that I would buy it, but it would be interesting.
Topre Enthusiast
08 Jun 2014, 20:47
There are low-profile Topre switches, but they are pretty crappy in my opinion.
There are some pictures of the internals for them here, too.
08 Jun 2014, 21:34
What's crappy about them, specifically? And the same question for conductive Topre? I understand why they ought to be more compromised designs, but I can only guess the problem would be: reduced tactility squeezed into too short a throw, and too low activation point with a hint of rubber mush landing, respectively.
Topre Enthusiast
08 Jun 2014, 21:59
There's too much friction and I don't know if this is because the diameter of the sliders is much smaller than a standard Topre (yet still has to support a cap with the same area as a full-sized one) or the material used.
If you've had a close look at a standard Topre slider, you'll noticed it's a sort of glossy smooth and sometimes pitted appearance. This image illustrates it well I think:
The short-throw on the other hand looks like a more matte appearance and it reminds me of the sliders used for the large modifiers on Topre boards. The design of the switch housing's guides for the slider base is also quite different and could be altering the feel. This is all based on my limited use of the keyboard, as the short-throw boards are only available with whacky compact layouts that don't lend themselves well to extended use.
The conductive board isn't *too* bad. Before I opened the Sony board to discover they were not standard Topre, I actually figured they were just really aged or the board had been thrashed hard.
08 Jun 2014, 22:32
I quite like compact layouts in general, and the ones on the wiki don't look too bad. Nothing a spot of Soarer can't fix over PS/2, perhaps. If you know any for a good price, they might be something I'd like to checkout. Topre's G84!
Topre Enthusiast
08 Jun 2014, 22:53
We're kinda going off-topic here but maybe I'll send one over for a Euro Tour if there was enough interest.
It would certainly be a lot cheaper to ship around than the Realforce.
09 Jun 2014, 02:00
I'd be up for that. I doubt too many more people would be, though, as the Realforce tour is really about aspiring to buy a top of the line keyboard of your own.
Now I start imagining having a Model F tour!
Hypersphere
09 Jun 2014, 02:05
Muirium wrote:I'd be up for that. I doubt too many more people would be, though, as the Realforce tour is really about aspiring to buy a top of the line keyboard of your own.
Very well, send us your Kishsaver, please.
09 Jun 2014, 02:08
Yeah, maybe not that one. I was thinking more like an XT. And you guys can start your own over there!
Hypersphere
09 Jun 2014, 02:14
Muirium wrote:Yeah, maybe not that one. I was thinking more like an XT. And you guys can start your own over there!
No, no! You are the guys who are "Over There". We are here.
XTs are so readily available on eBay, everyone should be able to have one. Occasionally, they have a reasonable price. My current daily driver cost $51, but I got one in even better shape for $!9. It needs a bit of cleaning before sending it out on tour, however.
09 Jun 2014, 02:23
Believe it or not, but my Google search for sarcastic meme art of the theme "christopher columbus discovers the old world" seems to be flooded by false positives about him sailing to some other place; what a load of balls! Next up they'll try telling me he never reached India.
davkol
09 Jun 2014, 15:24
derp
bhtooefr
09 Jun 2014, 16:26
For a Model F tour, I'd use a 5155 keyboard, to be honest, simply to reduce shipping costs.
On-topic, if you don't mind having your own switch manufactured, there's always this beast, a scissor-stabilized transverse buckling spring: https://www.google.com/patents/US5268545
jacobolus
10 Jun 2014, 10:34
Cherry ML works great as long as your keycaps don’t have corners, and you don’t mind some plastic-on-plastic scratchiness.
olafweller
12 Jun 2014, 23:51
Hey guys, sorry it took so long for me to react! Thanks for all your comments. Also your additional comments about legends Daniel Beardsmore
The reason why I am looking for a keyswitch that is as thin as possible is because the keyboard will be very small so the battery/PCB and buttons will be stacked on top of each other.
After reading your comments I am not that confident about Cherry ML... I will ask the producer to send some over so I can have a feel of them. I saw somebody advice XL, I will also ask for these although I am afraid that the height will be a no go.
About scissor switches, after some additional research I might have the idea that it is not realistic for our product. We are going to launch it on kickstarter and aim on a first production batch of about 2.000-5.000 pieces and scissor switches have to be integrated in a large production scale for it to be viable.
If anyone has a good suggestion for an off the shelve keyswitch which I could propose to the producer instead of the Cherry ML that would be great!
davkol
13 Jun 2014, 00:10
derp
olafweller
13 Jun 2014, 00:22
Maybe I should give them a call then
bhtooefr
13 Jun 2014, 03:39
Get a Cherry ML-4100, may also be known as a G84-4100. That's a whole keyboard+caps for ML switches at 18 mm pitch.
13 Jun 2014, 04:33
Yes. Much better to judge a switch when it's in a board and you can type on it, rather than just loose in your hand. Grab a G84.
The other Cherry switch mentioned was MX. You're on a better route to attention and success with that one, if you can design something smart around it. MX essentially owns "mechanical" these days. Going with anything else will be an uphill slope.
Evilcamels
13 Jun 2014, 04:59
It is too bad Space Invaders are no longer manufactured. Best 'low profile' switches ever made in my opinion. Cherry ML are the best option if you need low profile and tactile response, unfortunately they don't have MX stems like MY and aren't very popular
