SPRIT Model 1,2,3 PCB : Case : Parts (Closed)
sprit1
- Main keyboard: 60% Custom, Apple0110, NCR, HHKB
- Main mouse: Cherry, Logitec
- Favorite switch: Cherry, Alps Linear, Alps Tee Stem, IBM F
SPRIT Model 1,2,3 ::: PCB : Case : Parts
Acrylic Case Model 1,2,3* : All Solid 8T+10T :: Laser & CNC Machined
*limited copyright
Model 1 Standard (5mm Plate & 3-Layered Case : 28mm High Height * You may need a palmrest) $70~
http://geekhack.org/index.php?topic=505 ... msg1324241 http://geekhack.org/index.php?topic=505 ... msg1266826
Model 2 Slim (Top & 2-Layerd : 21mm Medium Height) $58~ Model 3 Super Slim (Top & 2-Layerd : 18mm Low Height, but higher than Poker II) $55~
http://geekhack.org/index.php?topic=505 ... msg1373251
- 60% Model 2, 3 supports : Face U, W, GH60, Poker I, and most 60% Custom PCBs (* Poker II users need a commnet)
- 75% Model 2, 3 supports : MX-mini U, W PCBs.
- 87% Model 2, 3 supports : A.87 PCBs, Phantom 87%, and Most 87% Custom PCBs.
- 110% Model 2, 3 supports : 110% A.87 Ext. PCBs, most 110% Custom PCBs.
PCB W * : Full LED :: SW & HW KeyMapping & Macro ::: GH & DT Version * :::: ANSI + ISO
- 60% (Face W), 75% (MX-mini W) PCB *copyright
- 87% (A.87W Tenkeyless), 110% W PCB *copyright
- All SMDs are pre-soldered (MOQ=100).
- The Latest Firmware & Key-Maps : Installed and Tested before shipping.
http://www.youtube.com/channel/UCLG-nNB ... M3w/videos
- ANSI + ISO in one PCB and Plate, wider Comaptibility for the Keycaps and Layouts (Concept design by SPRIT)
- Originally developed by the legendary BeastMask (The Creator of A.87, A.87Ext, MX-mini, and All the current versions. *copyright)
- 1.6mm thick Heavy duty dual-layered PCB.
- All keys are Programmable, SW & HW Keymapping, SW & HW Macro support.
- Supports FN key almost any position You like. (even at the Spacebar)
- Supports both Plate / PCB connection with the Case (Design by SPRIT for Systematic reasons)
- Supports newly designed connecting Holes for the PCB with the Case (Design by SPRIT for Oscillatory Kinetic reasons)
- 60%, 87%, 110% Supports : Standard 1.25x 1.25x 1.25x 6.25x Winkey, 1.5x 1x 1.5x 7x 1.5x 1x 1.5 Winkeyless, 1.5x 1x 1.5x 6 x 1.5x 1x 1x 1.5 Winkeyless, 1x1.5x 7(6)x 1.5x1 60% HHKB.
- 75% MX-mini supports : 1.25x 1x 1.25x 6.25x 1.25x 1x1x (1x1x1) Winkey, 1.5x 1.5x 7x 1.5x 1.5x (1x1x1) Winkeyless,
- Supports All the available Keycaps (including the centered & off-centerd capslock, Cherry original & Non cherry keycaps and 6x, 6.25x, 7x spacebars.)
http://geekhack.org/index.php?topic=505 ... msg1179292 http://geekhack.org/index.php?topic=505 ... msg1353538
*limited copyright
- M1 60% PCB ANSI+ISO Black 11.jpg (766.24 KiB) Viewed 9341 times
- Model 2, 3 60% Clear - Turquoise - Mixed - 15.jpg (614 KiB) Viewed 9346 times
- - 60% PCBs left - 0718.jpg (847.96 KiB) Viewed 9569 times
- bazh
Ah, one more thing, I will move to Finland in about the later half of August so I'm not sure about the shipping address now, will it be possible to change address then? Or should I just fill in the Finland address to this?
Thank you sprit, I really want to get my hands on these pcb
- Medowy
- Main keyboard: HHKB Pro 2 Type-S
- Main mouse: G500s
- Favorite switch: MX Black
Welcome to Finland friend! Where will you be staying?
Sorry for messing up the thread ;c
- bazh
sprit1
- Model 1 60% 75% 110% - 15.jpg (762.84 KiB) Viewed 9198 times
sprit1
- Model 2 110% Blue - White - Blue - 11.jpg (562.41 KiB) Viewed 9209 times
sprit1
_robban
- Main keyboard: CM Novatouch TKL w damping and Granite Caps
- Main mouse: Mad Catz Cyborg R.A.T. 9 ...
- Favorite switch: Topre baby, Topre
Just sent my order for 1 complete full size as well as an additional case for my ducky, great effort you have putt into this GB spirit1
sprit1
- Cheesebaron
- Main keyboard: GH60 - Massdrop ALT
- Main mouse: Mionix Naos 7000, Kensington SlimBlade
- Favorite switch: Buckling spring, Cherry MX Blue
Did anyone receive their order? I've tried emailing twice, but no answer. I would really appreciate an update.
_robban
https://geekhack.org/index.php?topic=50580.2940 <-- I haven't received my order either and we are not the only one apparently. Seems like if the work involved in this GB was a bitt bigger than Mr Sprit1 expected in the first place. As for now we can only wait and hope that it arrives... sometime...
- Cheesebaron
Alright. I had hoped an update on my mails or that Sprit officially stated that this many have been shipped, this many are missing etc. I'll wait a bit more... Interest rate on this one is really bad, could have used that money on gold instead..._robban wrote:https://geekhack.org/index.php?topic=50580.2940 <-- I haven't received my order either and we are not the only one apparently. Seems like if the work involved in this GB was a bitt bigger than Mr Sprit1 expected in the first place. As for now we can only wait and hope that it arrives... sometime...
