What mouse/trackball do you use with your ergo KBD?
flopix
29 Aug 2014, 14:20
Hi all,
I'll be getting an ergodox hopefully in the next month or so and I was wondering what mouse or trackball should I get. My current setup is 2 screens, normal keyboard + mouse. I saw some custom builds with trackballs in the middle.. Is this the way to go?
Of course, pics help for inspiration :)
Cheers,
Max
30 Aug 2014, 01:35
I think that going with a trackball is the way to go otherwise your mouse arm might be over extended a bit. But as for some options away from the norm, I think a track-pad/joystick could also work out really nicely.
There are a few trackballs that a lot of people seem to like, the two on the top of my head are; the Kensington expert mouse and the Kensington slimblade. Those I just listed are also ambidextrous trackballs so you could alternate hands with the trackball pretty easily.
A trackpad with a ergo dox has been done before by rambunctious. I'm not sure how well it worked but here's a picture:
So as far as trackpads go I think the best is the magic trackpad that you see in the picture. You have to do a bit of leg work to get it to work with windows though, here's a link to a guide for getting it to work with windows:
http://www.labnol.org/software/apple-ma ... ows/14158/
A joystick would definitely be unique. I don't think anyone has ever gone with an all-out flight-sim type joystick with an ergo dox before. As for which joysticks are good I really don't know.
davkol
30 Aug 2014, 15:39
derp
verbietet
30 Aug 2014, 20:42
I am in the same situation and thinking about a track pad solution. It looks neat and probably will save a a lot of desk space.
However, I linux mostly. I'm not sure how well the track pad works on it.
flopix
13 Sep 2014, 22:53
I'll be trying a trackball in the middle setup for starters. It's been years since I used last one but I'll post updates when both my dox and ball arrive. I wish someone would build a complete setup wit the dox we could use as reference.
nisilhum
03 Oct 2014, 14:15
MIcrosoft Natural used like rollermouse interesting
