Why store passwords in some unsafe cloud? When you can have them inside your keyboard!
http://youtu.be/NYISDdXiGmY
Great idea. Now only put a masterpassword on your keyboard....
Store passwords in your Teensy keyboard
If there's a key logger, you're screwed anyway.
In fact, merely avoiding the appearance of having a mysterious box on your desk that could be a keylogger is a big reason for people to build their Soarer's converter inside their keyboard at work, in case someone freaks when they see the Teensy!
- DT Pro Member: 0167
Work always freaks with anything non standard plugged into USB, i got funny looks with a bluecube back when i had the ML keyboard.
- pietergen
- Main keyboard: none yet
- Main mouse: none - keyboard shortcuts
So, the other way around: if you would want to put a keylogger on someone's computer, be sure to put it *inside* their keyboard
- Main keyboard: Microsoft Natural 4000
- Main mouse: WontSay
- Favorite switch: none
People have stored much more in Teensy... For a short read, look at the videos toward the end.
http://www.securitysift.com/fun-with-teensy/
And unfortunatly others are abusing firmware update without hardward dip-switch to upload such payload in keyboards...
- Main keyboard: IBM Bigfoot
- Main mouse: CST trackball
- Favorite switch: IBM Model F
Regarding the OP, it's a nice idea, but I have over 200 passwords, which I currently manage with KeePass. What would be useful though is end-to-end encryption from the keyboard controller to the application (either PC or web-based). That way, as long as you maintain physical security over your keyboard, you're protected from man-in-the-middle attacks.
