NCR and other old keyboards
VERGiL
26 Sep 2014, 08:39
A colleage at work showed me some of his other old keyboards.
Unfortunately they're not for sale :)
First is a NCR brand, with a self-"stickered" case. Should have Vintage Blacks.
Second is a Cherry, should also have Vintage Blacks.
Third brand is something like "multi key", my colleage said. Has a solid metal case.
26 Sep 2014, 09:07
The NCR should really be without that sticker! Such a nice industrial grey!
:mad:
The 2nd is MY, only the key caps are worth something.
What abiut the 3rd one, what kind of switches does it have?
chzel
26 Sep 2014, 16:06
The 3rd ones' caps look like SIEMENS Clicky
so perhaps RAFI?
26 Sep 2014, 19:11
that space bar on the NCR
its sweet
DanielT
26 Sep 2014, 19:36
andrewjoy wrote: that space bar on the NCR
its sweet
Yep, I like big ass space bars too :evilgeek: Too bad modern boards don't have them, and the trend is to lose the space bar, tinnie split space bars is the future
I just bought an old Wyse key set with a huge space bar like that one :D
26 Sep 2014, 19:47
DanielT wrote: Yep, I like big ass space bars too :evilgeek: Too bad modern boards don't have them, and the trend is to lose the space bar, tinnie split space bars is the future
then you will like my dream layout
i need that in my life with the getto reds with the light springs i was talking about ( MX pink?) and some super thick PBT caps
DanielT
26 Sep 2014, 20:26
That with a short right SHIFT and Fn next to it and is perfect. Big space bar rules :D
26 Sep 2014, 20:37
HHKB style Fn would make it bearable at least! Then split the backspace key, swap with backslash, and maybe cut 3 units off the you know what and…
DanielT
26 Sep 2014, 20:55
never off you know what :P
