I just installed custom keycaps from Group By 4 (Spherical: http://deskthority.net/wiki/Round4_SPH).
All the keys work fine, except for the space bar. When i press it on the left or right side, it get's stuck! It will then stay permanently down on one side. For now i'm using the original Filco spacebar, but it feels so weird, because it's lower compared to the rest of the keys.
I've tried inserting dampening rings under the switch (and where the stabilizer is), but it doesn't help. Any idea how to fix this? Here's a similar case with a Das Keyboard: https://www.youtube.com/watch?v=5b64psDiM6Q
Filco Custom Spacebar Stuck - How To Fix?
- chzel
- Main keyboard: Phantom
- Favorite switch: Beamspring, BS, Vintage Blacks.
- DT Pro Member: 0086
Try removing the stab inserts and test.
1) If it does bind there is something wrong with the switch mount.
2) If it doesn't there is probably something wrong with the stabilizer mounts.
2.1) Install one stab, test. If ok install second, test.
2.2) Look for any deformities on the offending post.
3) Snap a photo of offending post and show us!
- Main keyboard: Filco TKL with Red or Blue
- Main mouse: Logitech G500
- Favorite switch: Cherry Red, Blue, Vintage Black, Topre
SOLVED: the stabilizer stem needs to point DOWN. my bad
thanks for the tips chzel!
finally got these awesome caps in order! ill post some pics soonish.
