That's the layout I would like but I really have no clue how to get it like that. I think it's advised that I should use a teensy but I'm not sure I even have enough space to program it.
So a few questions:
Will the teensy have enough little spaces for the 16 columns and 5 rows?
How will I program an LED under the caps lock key to turn on?
How do I even attach the LED to that little hole in the keyswitch?
And most importantly HOW is it actually done? I've looked at hasu's codes but can't make head nor tail of what they mean?
Can someone direct me towards a guide pleassse
I found a place that can water cut my design, gonna get an acrylic keyswitch slot made to test that I have the shape correct.
When I've done this though does anyone know how to get the switch out or will I have to break the acrylic plate open?
