Hello,
I got a noppo choc mini a while ago, and it is advertised (and reviewed) to have NKRO over USB. But mine seems to be stuck at 6KRO. Does anybody know what the problem might be and how to fix it? Maybe a problem with the firmware?
I've tried it on Windows, Mac, and Linux on multiple machines.
Thanks!
Noppoo choc mini NKRO problem
Weird, eh? Tried it without a USB hub? And does the keyboard have any DIP switches? I'm just throwing out random suggestions because, really, you've tried the important part: several systems, several OSes, and no NKRO. That ain't right.
Do you have Noppoo's box and manual? Maybe they sneakily changed it…
- CeeSA
- Main mouse: MM711
- DT Pro Member: 0016
Did you try USB connections direct on the motherboard? Case USB connectors are often of poor quality.
