Burroughs D8585 Keyboard - 4802-1115-501 Rev G
HaaTa
Master Kiibohd Hunter
21 Nov 2014, 03:39
So this keyboard...it is technically the oldest computer keyboard I own. Circa ~1968, with switches from 1967.
It also took me multiple months to acquire the keyboard from the seller. He didn't want to split the keyboard from the monitor and power supply. But the story goes he had a body builder carry the power pack into his basement...
Anyways, behold this marvel of 1960's engineering.
Imageburroughs-08585_1 by triplehaata, on Flickr
ImageDSC_0620 by triplehaata, on Flickr
ImageDSC_0621 by triplehaata, on Flickr
ImageDSC_0622 by triplehaata, on Flickr
ImageDSC_0631 by triplehaata, on Flickr
ImageDSC_0638 by triplehaata, on Flickr
ImageDSC_0637 by triplehaata, on Flickr
ImageDSC_0649 by triplehaata, on Flickr
ImageDSC_0655 by triplehaata, on Flickr
ImageDSC_0656 by triplehaata, on Flickr
ImageDSC_0658 by triplehaata, on Flickr
ImageDSC_0660 by triplehaata, on Flickr
ImageDSC_0667 by triplehaata, on Flickr
ImageDSC_0670 by triplehaata, on Flickr
ImageDSC_0678 by triplehaata, on Flickr
ImageDSC_0687 by triplehaata, on Flickr
ImageDSC_0698 by triplehaata, on Flickr
ImageDSC_0718 by triplehaata, on Flickr
ImageDSC_0717 by triplehaata, on Flickr
ImageDSC_0719 by triplehaata, on Flickr
ImageDSC_0751 by triplehaata, on Flickr
ImageDSC_0753 by triplehaata, on Flickr
ImageDSC_0772 by triplehaata, on Flickr
ImageDSC_0778 by triplehaata, on Flickr
ImageDSC_0782 by triplehaata, on Flickr
ImageDSC_0790 by triplehaata, on Flickr
ImageDSC_0789 by triplehaata, on Flickr
ImageDSC_0792 by triplehaata, on Flickr
ImageDSC_0793 by triplehaata, on Flickr
ImageDSC_0795 by triplehaata, on Flickr
ImageDSC_0796 by triplehaata, on Flickr
ImageDSC_0798 by triplehaata, on Flickr
ImageDSC_0799 by triplehaata, on Flickr
ImageDSC_0807 by triplehaata, on Flickr
ImageDSC_0808 by triplehaata, on Flickr
ImageDSC_0816 by triplehaata, on Flickr
ImageDSC_0829 by triplehaata, on Flickr
ImageDSC_0839 by triplehaata, on Flickr
ImageDSC_0840 by triplehaata, on Flickr
ImageDSC_0843 by triplehaata, on Flickr
ImageDSC_0845 by triplehaata, on Flickr
ImageDSC_0849 by triplehaata, on Flickr
ImageDSC_0851 by triplehaata, on Flickr
ImageDSC_0852 by triplehaata, on Flickr
ImageDSC_0854 by triplehaata, on Flickr
ImageDSC_0804 by triplehaata, on Flickr
REVENGE
21 Nov 2014, 03:45
It's a key board.
21 Nov 2014, 03:47
What better than a spaghetti keyboard for writing spaghetti code?
It's in reassuringly clean shape. I like those switches. They remember to say they're switches on the outside!
pyrelink
21 Nov 2014, 03:51
Hey those look exactly like the Micro Switch Reed Switches I have. Are the switches in the beige casing anything specifically different from the black cased ones?
HaaTa
21 Nov 2014, 09:03
Yeah, I'm pretty sure they are the same as yours.
If you look at the full album, I did take apart various switches to see if there were any differences. The single grey/beige one just seemed older. The bottom piece did look different though, it had more holes. Inside, the switches were basically the same.
lowpoly
21 Nov 2014, 13:46
Why does the keyboard wrap around the table?
21 Nov 2014, 13:53
Because low profile!
I'm not sure if this is what they were doing, but here's IBM's version of the idea:
Beamspring Desk
Beamspring Desk
At least you never have to worry about keyboard slipping, or lost feet, or any adjustment whatsoever. Quit worrying and learn to love our Sci-Fi retro future!
nourathar
22 Nov 2014, 09:27
wow !
quantalume
22 Nov 2014, 17:59
Wow, imagine how many hours of labor went into making that keyboard. My sister used to work for Burroughs around that time frame, in Detroit, back when it was a functioning city.
daedalus
Buckler Of Springs
22 Nov 2014, 18:47
Muirium wrote: Because low profile!
I'm not sure if this is what they were doing, but here's IBM's version of the idea:!
Not sure what that Burroughs machine was for, but that contraption, the IBM 3741, was designed as a replacement for keypunch machines. It stored data onto 8" floppy disks, instead of on cards.
The thing I love the most about those things is that the CRT tube is mounted vertically inside the desk, and the "screen" on the desk is actually a mirror. That picture sort of demonstrates that phenomenon well. The System/32 had a similar design:
See here
22 Nov 2014, 18:50
I guess they wanted your eyes straight ahead on whatever you were transcribing then? Because the ergonomics of that low, far off axis, screen are made of nightmares!
Edit: Having read your link, I'm flummoxed quite what this is:
But its position in front of the user suggests significance beyond that pokey little display.
facetsesame
Mad Dasher
22 Nov 2014, 19:28
The whole Burroughs terminal(?) setup looks like it belongs on a battleship or something. Just as well it fixes to the desk, I wouldn't want that dropping on my toes. Though admittedly I might not have the heft to do that accidentally.
The stark contrasting mono scheme with circular buttons makes me think of an unrelated but contemporary design by V & E Friedland...
As for the IBM 3741, it's a very nice dream. I have a feeling I'd end up with a stack of alternate keyboard modules! In a modern setting (I'm not advocating anything sacreligious here), the advantage of such a display set up would mean you could have a large display straight ahead and entirely indepdent, and the built in display could provide status messages, like a sort of (dare I say the word) annunciator. But that is not the world I live in.
jacobolus
22 Nov 2014, 23:01
On ebay: “IBM Mohawk Keypunch Keycard Keyboard Machine ??” http://www.ebay.com/itm/321593760515
mr_a500
22 Nov 2014, 23:04
Nice find. I'd love to have toggle switches, lights and a counter on a keyboard. It's a pity I don't like that Burroughs keycap shape.
HaaTa
23 Nov 2014, 03:49
The original ebay listing had the title: VTG BURROUGHS LOGIC UNIT MODL 08585
IIRC, the seller said that it was for Airplane reservation system. Makes sense if you look at the keycaps.
facetsesame
Mad Dasher
24 Nov 2014, 22:45
That style of keycap definitely reminds me of something!
mr_a500
24 Nov 2014, 22:54
I first saw this keycap style in an ad for surplus keyboards in the first BYTE magazine:
(BYTE Sept. 1975)
facetsesame
Mad Dasher
24 Nov 2014, 23:11
If only we'd been there at the right time! Not sure I'd be up to wire wrapping up a Teensy clone though.
mr_a500
02 Dec 2014, 15:45
HaaTa wrote: Anyways, behold this marvel of 1960's engineering.
I knew this terminal looked familiar. Here's a BYTE ad from June 1977:
...and when I looked again at the terminal from The Thomas Crown Affair (1968), I noticed that the key colour scheme is similar. I know it's not the same terminal, but take a look at the line of white keys at the top of the keyboard:
I always assumed the Thomas Crown terminal had Selectric style (normal sphericals), but maybe that's because the resolution is too low. I wish I could get a higher resolution shot of this.
quantalume
02 Dec 2014, 19:23
Weight 210 lbs (95 kilos)! Sometimes it's just as well that things aren't made like they used to be...
mr_a500
31 Dec 2015, 00:55
I finally managed to get a higher resolution image of this and it is indeed Burroughs (and Micro Switch), but not the rounded keycap black & white type.
So it looks like the companies using Micro Switch rounded keys and went "Selectric style" before 1970, except UNIVAC, which stuck with their distinctive shape until at least the mid-70's.
