Cherry MX - White Keycaps - Where?
- Toast
- Main keyboard: FC200r
- Main mouse: Logitech g400
- Favorite switch: Brown
Figured this is as good a place as any to ask...
Where could I find some white keycaps (double shot, lasered, pad-printed, whatever) which might fit a Leopold FC200R?
Just a couple notes:
-I'm Canadian
-Not worried about every key. I know some of the Leopold keys are non-standard like the space bar.
-Would rather not buy an entire Cherry keyboard off ebay just for the keys.
Maybe there's no good answer. Thanks anyway! : )
-I'm Canadian
- sixty
- Gasbag Guru
- Main keyboard: DKSaver
- Favorite switch: Cherry MX Black
- DT Pro Member: 0060
I can probably help you out with Cherry keycaps. I will have a few more sets of double shots available for purchase soon, may still have some in stock now too. Lasered should be no problem in either case.
You would likely end up with incompatible keys for space, ctrl/win/alt/app (depends if you want lasered or double shot - lasered I have fitting ones... I think) and caps lock. Rest should fit fine.
Have to go home in a few minutes, so I'll report back with inventory tomorrow if you are interested.
- Minskleip
- Main keyboard: HHKB Pro 2
- Main mouse: CM Sentinel Storm
I'm also still interested in Cherry vintage double shot keycaps. I would have bought from you sooner, but got a bit stressed from my employment situation. Now I don't care; keycaps' where my money's at.
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
This is what sixty's hands look like after harvesting all the keycaps:
- sixty
- Gasbag Guru
To be honest... that is pretty close. Two weekends ago I pulled at least fifty boards. Result was 2 cuts and the freaking wire keycap puller finally broke.
Anyway, going home now. Gonna check if I have two sets tomorrow.
- Minskleip
I appreciate that a lot! One week or two doesn't matter though.sixty wrote:To be honest... that is pretty close. Two weekends ago I pulled at least fifty boards. Result was 2 cuts and the freaking wire keycap puller finally broke.
- Toast
Oh sweet, that would be rocking for me. Will be watching to see what you've got.
((If there were white with black lettering double-shots that'd make me drool. But sweet either way.))
Ouch on the cuts.
Ouch on the cuts.
- keyboardlover
- Main keyboard: Cherry G80-3494 Modded (home)/Realforce 87U (work)
- Main mouse: Handshoe Ergonomic Mouse
- Favorite switch: Cherry Ergo Lite Clears
@Sixty - I'm interested in another set as well, so let me know =)
- sixty
- Gasbag Guru
Yep. Thats exactly how its done. Ripster has an excellent guide for that over at geekhack.Toast wrote:Hm... wonder if I could find a way to mod the underside of the Caps Lock key so I could get it on the Leopold. Might be worth it. : 3 Some dremel action and epoxy?..
- mass
- Main keyboard: Em....
- Main mouse: Logitech Laptop
- Favorite switch: Alps Pink
Hi there, How much are you asking for a set?sixty wrote:Sorry, didn't manage to check stock last night, was too tired. Anyway, the sets I will (would?) be selling look like these:
Just need a set of US-layout Cherry Doubleshot KeyCaps.
Please PM me. thanks.
- keyboardlover
I'm also interested =)
- Toast
Oi, is just cool that you offered. I'd still like to buy if and when you do get them in. (Think I'll hold out for doubleshot-whites now though.)sixty wrote:I think I have none left now. I had a few sets from a source in Taiwan, right now I have none. Please wait a while. I'll PM you.
- keyboardlover
I call dibs!
- J888www
- Main keyboard: Keychron Q60 Max
- Main mouse: Logitech G309
- Favorite switch: Monterey Blue
Help is at paw, this Chinese Magic Oil works wonders, it aids/assists/promotes healing, you will be amazed, I tell the truth, I have not come to fool you.........One of the essential items kept in every Monkeys' abode.sixty wrote:Result was 2 cuts..........
Mau Lung Minjak Gosok Oil. NB: For external use only.
Do not mistake this with Indian Magic Oil which only makes your skin to become taut.
Wonder why no one have enquired about transparent laser etched key-caps. Would be very nice to show-off some of the switches ie: Sixty's transparent MX switch covers with Red cherry stems or for Blue ALPS and maybe/definitely for a certain Monterey SIIG MiniTouch.
"You're sooo vain, I bet you think this song is about you, you're sooo vain......................" Carley Monkey
Once you have found your Grail, you too will wish to "Pimp It Up"
- Toast
Hm, am curious. If I was patient and determined enough to mod all the stems of these keys to fit the FC200R...
Would the keys be the right size approximately? Shift, ctrl, alt, space, caps. This is what I hope I can do. : )
- sixty
- Gasbag Guru
Shift should fit out of the box. Caps can be modded. Ctrl, Alt, Space, nope.
CTRL and ALT keys on vintage Cherry keyboards (without winkeys) are sized 1.5 of a normal keycap, while on the modern boards with winkeys, such as the FC200R they are 1.25 sized.
- Toast
Ah okie, dang! Am still down for a set.
Maybe will do something like this guy did.
http://www.kbdmania.net/xe/photo/2094999 ((just attached since kbdmania is so slow))
- FC200R.jpg (112.1 KiB) Viewed 14605 times
- sixty
- Gasbag Guru
The good old AEK2 keycaps! Damn ALPS keycaps, that reminds me... I still owe a set of SGI arrow keys to daedalus that I somehow ended up putting on another ALPS board and then shipping to another geekhack member. Just one more reason to dislike ALPS.
