How does my parts list look?
sushi_ninja99
31 Dec 2014, 21:59
I'm attempting to build my own mechanical keyboard, but I'm trying to make it as inexpensive as possible. Here's my parts list so far:
100x semiconductors: http://www.digikey.com/product-detail/e ... -ND/458603 $4
Cherry mx blue switches: http://mechanicalkeyboards.com/shop/ind ... tail&p=652 $49
Tinsy: https://www.pjrc.com/store/teensy.html $16
Key Caps: http://mechanicalkeyboards.com/shop/ind ... ail&p=1003 $39
Stabilizer Clips: http://www.wasdkeyboards.com/index.php/ ... -2pcs.html $5 (W/S)
Steel+Aluminum Plates: ~$50 local steelshop
Acrlyic: $20 Ponoko
Wires: ~$5
Do I have everything included? Am I getting ripped off anywhere? Thanks!
Stabilized
31 Dec 2014, 22:23
You will need wire for the stabilisers, and you might want to look at other keycaps that may be cheaper as those are designed to allow backlight through.
If you can wait, Massdrop do the vortex pbt doubleshots pretty cheap every so often; I think the lately went for $20 a set.
Edit: these ones:
https://www.massdrop.com/buy/vortex-dou ... guest_open
Other then that, you look all set; let us know how you get on :D
sushi_ninja99
31 Dec 2014, 22:34
Do you know whether the steel and aluminum plates are reasonably priced? I've tried getting a quote from a number of places, but none of them have emailed back yet. Thanks for the advice on the keycaps. Originally, I had some for $20, but then I found out there was $10 shipping, so I thought it better to purchase these.
Stabilized
01 Jan 2015, 10:43
I am sorry, I don't really know about steel/aluminium plate prices; you may want to look around in the workshop subforum and ask around there.
I think they will also change depending on who makes it and what your design is like; speaking of which, do you have a plate design ready to go? This has been the area that has stumped me in the past, as I am terrible with CAD software.
IvanIvanovich
01 Jan 2015, 17:08
I usually buy old G80 or something, and take all the parts off. When you can find one whole board for like $30 or less and get switch, keycap, stabs, and possible other bits... it can really pay off to scavenge instead of buying things separately.
Depending on what layout you are going for, you could also possibly cut down/modify an existing plate to suit out of some broken board picked up for cheap.
01 Jan 2015, 17:51
IvanIvanovich wrote: I usually buy old G80 or something, and take all the parts off. When you can find one whole board for like $30 or less and get switch, keycap, stabs, and possible other bits... it can really pay off to scavenge instead of buying things separately.
This is a great idea. It's also how I got into MX blacks!
