The TrackPoint Topic
pkamb
15 Jan 2015, 23:15
A thread for discussion/appreciation of everyone's favorite ThinkPad pointing stick nub.
http://en.wikipedia.org/wiki/Pointing_stick
XKCD ALT: "I know a lot of people hate these, but I prefer them to touchpads."
CeeSA
16 Jan 2015, 09:26
I am not shure wether this fits the topic but
a "keyboard" life w/o trackpoints is unthinkable for me.
Trackpoint half.jpg (155.07 KiB) Viewed 6855 times
Halvar
16 Jan 2015, 13:17
Good topic! Where can I best cannibalize (or buy) one, and how to get it to work?
bhtooefr
16 Jan 2015, 15:02
The easiest one to cannibalize is the TrackPoint IV Keyboard, as (I think it's that one, anyway) it uses a completely physically separate controller for its TrackPoint. PS/2 attached, so if you've got a PS/2 mouse port, you can use it.
There's also this: http://sprintek.com/products/sk8702.aspx
And, I wonder what protocol they're using for the (USB-attached, with full drivers) TrackPoint on the previous ThinkPad USB keyboard. The current one is NOT fully configurable...
Halvar
16 Jan 2015, 15:08
Great info bhtooefr! I'll start to look out for that.
pkamb
16 Jan 2015, 19:05
Personally I use the ThinkPad USB Keyboard with TrackPoint (model number 55Y9003 or SK-8855, circa 2009-2013).
Design:
http://blog.lenovo.com/en/blog/the-keyb ... ped-design
The TrackPoint and 3 buttons are *great*. I also love the Big Delete Key and Home/End PgUp/PgDn cluster, which I use all the time. Great programming keyboard. Perhaps anathema to mechanical keyboard types.
Photo by Masashi Nakano
I have also purchased but have yet to switch to the Japanese version of the same, which has a tiny spacebar to make room for many additional hotkey buttons. I'm not quite sure how I'll use them, yet.
Lenovo has unfortunately retired my keyboard in favor of a chiclet style keyboard, to match their newer ThinkPad laptops.
I will likely try this eventually, but am not looking forward to "normal" Delete cluster compared to the old version. TrackPoint still looks good though.
A good review of the new keyboard and the old:
http://www.jessebandersen.com/2013/12/l ... oards.html
And more great photos:
http://benjaminhorn.io/post/thinkpad-co ... rackpoint/
bhtooefr
18 Jan 2015, 17:07
It's worth noting that the keyboard you use now has the fully tunable TrackPoint drivers that ThinkPads use, whereas the new keyboard has much simpler drivers that, as far as I know, don't offer adjustable sensitivity.
18 Jan 2015, 18:50
CeeSA wrote: I am not shure wether this fits the topic but
The orange keys are mouse buttons?
davkol
18 Jan 2015, 19:05
derp
jlwinkler
28 Jan 2015, 21:40
Hey,
I would like to build a trackpoint into the Microsoft Slupt ergonomic keaboard.
Does anyone have a recommendation on what I need and where to get all that stuff?
I do not want to wire the trackpoint up with the electronics of the keyboard and I will be fine with a USB-cable solution in the end because I will not move the keyboard in my table too much in the end.
Thanks a lot in advance for every piece of input!
Cheers, JL
CeeSA
28 Jan 2015, 21:45
Findecanor wrote: The orange keys are mouse buttons?
yes, you are right.
