I found it in the Trash-bin !! (1992 IBM Model M Danish)
Peter
22 Jul 2011, 19:22
On the way home from our local Lidl-discount market I found this :
scan 3.jpg (251.22 KiB) Viewed 2675 times
scan 4.jpg (262.03 KiB) Viewed 2675 times
scan 6.jpg (865.84 KiB) Viewed 2675 times
scan 11.jpg (226.47 KiB) Viewed 2675 times
scan 7.jpg (161.46 KiB) Viewed 2673 times
It looked like SH*T, but nothing worse than what a 10% Hydrogen-peroxide solution can fix !
Se scan 11, that answered a question I've had for some time :
What do you do if you don't have a sleek 7/32" nut-driver (=5.5 mm !) ?
Well, You take a 1/4-inch top, heat it and .....
Ascaii
The Beard
22 Jul 2011, 20:28
did you seriously burn a hole in the lower shell to get the screws out, lol?
you can get a 5.5mm driver for about 8 €...
Very nice find, congratz
Peter
22 Jul 2011, 20:45
NO.. I most certainly did NOT ruin it by doing that!!
'It was like that when I found it' .. As Homer would say :)
However, I can somehow understand why the original owner did it :
I went in to this local store that claims to be a specialist in tools and asked for a 5,5mm nut-driver ..
The answer : ' I don't think such a thing exists'
You should have seen the guys face when I then asked for a 7/32" nut-driver :) :)
ripster
23 Jul 2011, 01:52
Haha, as an Ugly American even I'll admit technically 5.5mm is the more precise fit.
I like the keys especially. I cross my 7s but not my Os and what's wrong with just typing A then E?
23 Jul 2011, 01:56
I think I recognize the problem. I had a 5.5mm bit from a snap-on set, but due to the outer width it didn't fit the hole.
Ascaii
The Beard
23 Jul 2011, 20:35
I managed to find my "precision 5.5mm nut driver" in a german electronics store called Conrad for about 8€
