Alps SKFL LED
From Deskthority wiki
Alps SKFL LED
Manufacturer Alps Electric
Family Alps SKFL
Product code SKFL or SKFLxx
Switch type Linear
Sense method Metal leaf
Total travel ca. 3.7 mm
Keycap mount Alps mount (variation)
Switch mount PCB mount
Alps SKFL LED is the integrated LED version of the Alps SKFL switch. The only difference between the two switches is the lid, which with SKFL LED has a hole for the LED.
Keyboards
Other equipment
  • Roland TR-909[2]
Gallery
The loose switches below were part of a Technology Transplant Roland TR-909 Red Switch Set purchased from Musikhaus Korn in Germany.
Disassembly
Attempting to disassemble the switch is difficult and likely to cause damage. Inserting a screwdriver to release the sides of the lid will tear apart the switch, and gripping the legs of the lid will flatten them and lose their distinctive shape.
See also
References
  1. Deskthority — Tulip LT 286
  2. Musikhaus Korn — Technology Transplant Roland TR-909 Red Switch Set (German) Retrieved 2015-07-22.
