It says 2, 12, 13, 14 is already sold.Roman wrote: 05 Aug 2021, 05:26 https://www.avito.ru/nizhniy_novgorod/t ... 2183792727
Big list of keyboards to identify. Sadly, number 12 (appears to have Blue Alps) has already been sold. I am currently most interested in numbers 8 (could be SMK 2nd gen Cherry MX mount) and 15 (White Alps or clones?; seems to have legends above the keys similar to Ortek MCK-101).
IDENTIFY THE KEYBOARD thread
inozenz
Roman
- Main keyboard: KBDfans D60 (Zilent 67g)
- Main mouse: MacBook trackpad / Glorious Model O-
Number 8 appears to be a Chicony KB-5191.Roman wrote: 05 Aug 2021, 05:26 https://www.avito.ru/nizhniy_novgorod/t ... 2183792727
Cyber Junkie
- Main keyboard: Logitech Y-UY95
- Main mouse: Logitech G5
- Favorite switch: Click
Ibm or? big din connector. Thanks
- IMG_20210806_160846.jpg (3.08 MiB) Viewed 9171 times
Cyber Junkie
Opened it and found Datacomp DFK-101. Now to try it.
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
I'm pretty sure that #15 has Oriental Tech switches (see also this), not white Alps. OK switches are reported to be nasty.Roman wrote: 05 Aug 2021, 15:45Number 8 appears to be a Chicony KB-5191.Roman wrote: 05 Aug 2021, 05:26 https://www.avito.ru/nizhniy_novgorod/t ... 2183792727
- Lalaland124
- Main keyboard: 3278
- Favorite switch: Beamspring
Supposed to be an old Siemens keyboard. Any guess on use-case and switches?
- 20210808_200955.jpg (38.29 KiB) Viewed 9012 times
- 20210808_200938.jpg (25.44 KiB) Viewed 9012 times
Jan Pospisil
- Main keyboard: BTC 5169
- Main mouse: CZC GM600
Based on the model number, it's an ICL keyboard. According to some catalogs they used anything from the KPQ hybrid switches to Fujitsu Peerless, space invaders and Keytronic foam and foil.
Personally it reminds me of the various rebrands of the Acer 6310 series, but it could just as easily be a rubber dome.
c0burn
- Main keyboard: Dell AT102W
- Main mouse: Logitech G510
- Favorite switch: Buckling
Thanks. Where did you find the ICL model numbers?Jan Pospisil wrote: 17 Aug 2021, 21:28Based on the model number, it's an ICL keyboard. According to some catalogs they used anything from the KPQ hybrid switches to Fujitsu Peerless, space invaders and Keytronic foam and foil.
Jan Pospisil
In a few places, among others here:c0burn wrote: 17 Aug 2021, 21:36Thanks. Where did you find the ICL model numbers?Jan Pospisil wrote: 17 Aug 2021, 21:28Based on the model number, it's an ICL keyboard. According to some catalogs they used anything from the KPQ hybrid switches to Fujitsu Peerless, space invaders and Keytronic foam and foil.
http://www.rf-china.com/n18/oct.asp
- keybored
- Main keyboard: ibm m122 (not really)
- Main mouse: MM711 with a kailh medusa Y inside (don´t ask)
- Favorite switch: gtc dome with slider (jk)
new in this forum!. this thread looks really fun
i have this buckling spring keyboard and have no idea what brand it is, or if its even good.
looks and feels brand new
it feels quite smooth but some keys sound less "clicky"
- raoulduke-esq
- Main keyboard: Current in the rotation: Silver Badge
- Main mouse: Magic Trackpad 2
- keybored
thank you!
forgot to show the switches. looks like a buckling spring over membrane
- raoulduke-esq
I stand corrected - the concavity on the backplate you showed usually suggests domes but you have an interesting exception here!
- Palatino
- Main keyboard: Fluctuates.
- Main mouse: Of no interest.
- Favorite switch: Too early to tell.
Yup, Can Tech buckling springs, easy to mistake for rubber dome. I'd love to try these at some point.
https://youtu.be/un65h8NWSAE
- raoulduke-esq
One trick for IBM buckling springs that don't feel the same is to remove the cap, make sure the end of the coil is rotated to the 1200 position, tip the board so the springs fall back to the 1200 position, then reattach the cap. No idea if that works here.
Lyrics
Found this board in the 'Museum' at work. It's basically the attic, but the boss doesn't get rid of anything, really. So far I've found that it uses Alps SKCC switches, and was used somewhat in connection with a phone line, hence the 'numpad' with * and #. But that's about all I can find. Anyone got some more intel?
inozenz
sadly no info but i really like the color schemeLyrics wrote: 27 Aug 2021, 20:03 Found this board in the 'Museum' at work. It's basically the attic, but the boss doesn't get rid of anything, really. So far I've found that it uses Alps SKCC switches, and was used somewhat in connection with a phone line, hence the 'numpad' with * and #. But that's about all I can find. Anyone got some more intel?![]()
- zrrion
- Main keyboard: F122
What a nice looking board.
The stem colour looks off to me, as does the mount on the slider. Are you able to get more detailed pictures of that switch? If my spider senses are right that might be a grey GI SKCC switch. If it is that would explain why it has what appear to be non-APLS made caps. My guess is that those are comptec made caps, if you can get a picture of the underside of the cap that could be easily identified as well.
Lyrics
The keycaps are dirty but in good shape, the case has some surface rust, but nothing major! I'd love to get it to work one way or another. But that's for later.
I'll make some in-depth pictures tomorrow of the switches and keycaps, as well as some other aspects like PCB and connectors. Gonna check out the Caps Lock as well, since that seems to be a toggle switch. As in it stays down when you press it. For some reason that intrigued me more than it should.
- zrrion
latching switches are super cool. I don't think any of the standard toggles should be a think on a modern 101+ key keyboard but that doesn't stop latching switches from being really cool. Looking forward to seeing more pictures
- zrrion
those stems don't look like normal SKCC. I'm pretty sure those are GI SKCC: wiki/General_Instrument_Series_S950
Specifically it looks like S95010: wiki/File:General_Instrument_S95010_--_ ... _table.jpg
normal SKCC has a much more square stem but this one has some chamfers on the cruciform that align it way more closely with GI A95010. It also doesn't appear to match SKCC cream in colour but that could be an issue with colour balance in the photos.
I don' think the caps are comptec SA, but they could just be a variation I'm not familiar with.
- gilis
- Main keyboard: custom bord tgr 910
- Main mouse: mx vertical
- Favorite switch: tangerines v1
https://imgur.com/a/ZRbeWLm
what of these keyboards?
SomewhatHammer
- Main keyboard: Random Red Switch Mechanical
- Main mouse: Cheap gaming mouse lol
- Favorite switch: Cherry M7
http://imgur.com/gallery/1t3PNud
Losing my mind over this keyboard... I cannot find it anywhere but some Chinese website that makes you install an app to view an article that may or may not feature it.
I used Google lens to find that website.
I'd love to know exactly what this keyboard is. I looked at the "list of every cherry keyboard" section on this forum's wiki and didn't see it. I have a few other rare M7 Cherry boards I picked up recently in case anybody's interested in seeing those too.
Good luck!!!
Good luck!!!
SomewhatHammer
http://imgur.com/gallery/osRWYbo
Here's the other keyboards I got in case anyone here has any information on them. I'm not an expert by any means so any info is helpful!
ExZKV
- Main keyboard: Razer Blackwidow
Good day.
Please help me to identify my keyboard.
Switches: Topre
Weight: 2.6 kg (5.7 lb)
Connector: mini DIN-8, but pinout not the same with anyone other mini DIN-8:
1 thru IC7416 inverter to pin 35 D8749HC processor "Program Output"
2 thru IC7416 inverter to pin 1 D8749HC processor "Test 0 input/output"
3 +5V
4 thru IC7416 inverter to pin 39 D8749HC processor "Test 1 input"
5 thru IC7416 inverter to pin 37 D8749HC processor "Program Output"
6 +5V
7 GND
8 GND
It seems to me that there should still be some strip above the F-buttons, but it is lost
From what is this keyboard and how much may it cost?
Switches: Topre
3 +5V
6 +5V
7 GND
8 GND
- IMG_20210905_173141.jpg (2.1 MiB) Viewed 7933 times
- IMG_20210905_173240.jpg (1.3 MiB) Viewed 7933 times
- IMG_20210905_173248.jpg (4.01 MiB) Viewed 7933 times
- IMG_20210905_173515.jpg (683.61 KiB) Viewed 7933 times
- IMG_20210905_173745.jpg (3.92 MiB) Viewed 7933 times
- IMG_20210905_173753.jpg (4.15 MiB) Viewed 7933 times
- IMG_20210905_173619.jpg (464.62 KiB) Viewed 7933 times
- IMG_20210905_173642.jpg (747.04 KiB) Viewed 7933 times
