Unknown Keyboard
10ko
21 Jul 2015, 09:28
Hi guys,
Where is it from?
Thanks
terrycherry
21 Jul 2015, 09:54
Good to see your rare keyboard. If you make the good focusing to the switch directly, it could be easily to determine.
21 Jul 2015, 10:00
I suspect it's from the UK, with the " under 2 and with a pound sign on it. Do you own this keyboard? What kind of switches does it have?
21 Jul 2015, 10:02
Carefully pull a keycap and get a good shot of the switch if possible. Very interesting layout. Also the back of the PCB could shed some light.
10ko
21 Jul 2015, 10:53
21 Jul 2015, 11:04
Hmm still hard to tell for me. Key Tronic foam and foil?
http://deskthority.net/wiki/Key_Tronic_foam_and_foil
10ko
21 Jul 2015, 12:09
Usual electro mechanical (of course) contact over PCB.Look at right by zero.
Madhias
BS TORPE
21 Jul 2015, 12:25
I can't help with the keyboard identification, but I do see a Futura font face on the PCB.
terrycherry
21 Jul 2015, 13:03
what a strange keyboard I ever seen.
The slider look like the key tronic only. Nope to say what kind is that dirty boy.
Tactile or linear?
It might be the electrostatic or magnetic switch keyboard. Looks like an various of IMS international keyboard...
http://mousefan.telcontar.net/image/IMS.htm
21 Jul 2015, 13:08
Your a dirty boy! Dirty Dirty boy!
It does look a bit foil on foam is to me but i have never seen one with a pin thorough the PCB like that , strange.
21 Jul 2015, 13:29
mr_a500, HaaTa or dorkvader need to have a look at this.
terrycherry
21 Jul 2015, 13:48
or the contact of the slider like Haata owns: Quotron 855 - Scantlin Switches
http://deskthority.net/external-f34/bes ... t4455.html
21 Jul 2015, 13:54
terrycherry wrote: or the contact of the slider like Haata owns: Quotron 855 - Scantlin Switches
Then it's a rare one. :shock:
10ko
21 Jul 2015, 14:14
That's all.
HaaTa
Master Kiibohd Hunter
21 Jul 2015, 17:21
Neat. Never seen this one before.
Definitely a contact leaf.
21 Jul 2015, 17:50
Achievement Unlocked: HaaTa Didn't Get There First.
Noteworthy!
terrycherry
22 Jul 2015, 06:07
The mystery cursor key situation doesn't mentioned at
http://deskthority.net/wiki/Cursor_keys
