Thanks for the update. Will it work with just a passive usb adapter? And how would you rate the F&F switches? Personally I love the ones on my regular BTC5100 though I know not many people do. The printing did look a bit ropey from the initial listing: raised off the keycap, not particularly hard-wearing, not particularly crisp - that about right? If you won’t use it I wouldn’t mind trying it after your delvings.Jan Pospisil wrote: ↑12 Oct 2021, 14:04Just got it. The caps are printed and the printing is..ehm, poor. They do seem original with that board. The switches are tactile foam and foil, the tiny top F row is something else with an external linear spring. (very pingy when pressed with some force)Palatino wrote: ↑25 Sep 2021, 18:48A very good point: the profiles do seem to match their rows - and the font is a match too. And I suppose the placement of the digits could be explained by the tooling already existing to print those combinations, e.g. Page Up and 9. But the lack of a 5 I don’t get. Maybe they didn’t have the tooling for that already as the numpad 5 is usually without a sublegend, but one of the keys on the keyboard other than on the number row does actually output a 5 when pressed in combination with - well, maybe Alt? Looking forward to you finding out the answers.
Just now I couldn't get it to work with a Soarer's, we'll see more about the layout and insides later when I open it up.
Overall it's a fun addition to the wiki, but not something I'd use, unfortunately. (because I do like the layout a lot)
Stuff you just bought
- Palatino
- Main keyboard: Fluctuates.
- Main mouse: Of no interest.
- Favorite switch: Too early to tell.
- Main keyboard: BTC 5169
- Main mouse: CZC GM600
It's not offensively bad, but I wouldn't want to use them daily. Not nearly as nice as the later dome with slider.Palatino wrote: ↑12 Oct 2021, 23:35Thanks for the update. Will it work with just a passive usb adapter? And how would you rate the F&F switches? Personally I love the ones on my regular BTC5100 though I know not many people do. The printing did look a bit ropey from the initial listing: raised off the keycap, not particularly hard-wearing, not particularly crisp - that about right? If you won’t use it I wouldn’t mind trying it after your delvings.Jan Pospisil wrote: ↑12 Oct 2021, 14:04Just got it. The caps are printed and the printing is..ehm, poor. They do seem original with that board. The switches are tactile foam and foil, the tiny top F row is something else with an external linear spring. (very pingy when pressed with some force)Palatino wrote: ↑25 Sep 2021, 18:48A very good point: the profiles do seem to match their rows - and the font is a match too. And I suppose the placement of the digits could be explained by the tooling already existing to print those combinations, e.g. Page Up and 9. But the lack of a 5 I don’t get. Maybe they didn’t have the tooling for that already as the numpad 5 is usually without a sublegend, but one of the keys on the keyboard other than on the number row does actually output a 5 when pressed in combination with - well, maybe Alt? Looking forward to you finding out the answers.
I'll experiment more and probably clean the thing this weekend.
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
NEC PC-9800 Series
Pic from the ebay ad.
* NEC linear cream oval switches.
* Stop key is an NEC heavy blue oval switch (blue oval slider with a plastic yellow strip on the top housing), which is as heavy or heavier than an Alps heavy blue (200g).
* Overall feel is like a heavier version of Fujitsu Leaf springs.
* When you press down the spacebar, it's flush with the bezel, which feels very odd.
* It's got a double smiley face Z (tsu) key ツ !
* Travelled to the US from Japan in less than 10 days. That's also shocking.
* Almost forgot: this thing has heavy, beautiful ping.
IIRC, there's a TMK adapter I can build for this thing, so it'll be some fun there. I have to get my hands on a female 8-pin mini-din, though.
What are the caps like? Some kind of lighter colour DS?
- hellothere
Yellowed .
If Wikipedia is any indication, they should be a creamy white for the main alphanumeric block and numpad and the modifiers/misc keys should be a light grey, but slightly darker than the case. The caps are thin double-shot with grey legends. I've owned/own several other KBs with NEC grey double-shot caps and they're very tricky to retr0bright, but I'll give it a shot.
- hellothere
The Wang cleans up nicely. I've got one with salmon Alps. Everything but the spacebar is dye-sublimed PBT or, with the blue legends, double dye-sublimed. You just have to remove the caps and ultrasonic them or soak in warm water with soap -- or Simple Green, if you prefer.
- hellothere
NTC KB-6151, with no letters after the model name.
This is the cheapest KB I've ever purchased, at $10, not including shipping.
NTC keyboards can have just about any kind of switch. I'm hoping for Omrons or blue Alps -- the bottom does say "Made in Taiwan" -- but even if it has alps.TW OA2, it means I have an OK keycap set and an Alps-compatible chassis with a metal bottom. It also makes up for me accidentally buying a rubber dome IBM a couple weeks back .
- dcopellino
- Main keyboard: IBM 4704 F400 brushed chrome
- Main mouse: Logitech laser wired
- DT Pro Member: 0229
Hello there, I've just bought an IBM 5576-1 with this auction on Yahoo Japan through buyee. https://page.auctions.yahoo.co.jp/jp/au ... 1026501168
I paid about 160€ with the sniper bid feature. My question to someone else who has previously had experience in buying from Japan is: what should i expect now as regards as custom fees? Would it be a bloody expensive adventure? Thanks for answering....
- Polecat
Northgate 101I. Well, I broke my $50 rule again, because this one has my favorite layout, and because they rarely turn up, even in crappy condition. This one needs literally nothing, except to be used and enjoyed.
This is one of the two Gen2 Northgate 101 models, pretty rare, and has very early white SKCM switches in lovely condition. Very clean, inside and out. Most of the 101I models I've seen had a plastic base, but to my surprise this one has a metal one. I compared the serial number on this one to the others in my database, and this one was at the end of the run, so it's presumably the earlier examples that were plastic. Only two switches on this one--XT/AT and Ctrl/Caps Lock swap. The cord is attached, unlike most Gen2 Northgates.
These are the seller's photos. I'll take some of my own if anyone is interested in putting it in the Wiki.
- 101i_1.jpg (324.29 KiB) Viewed 29921 times
- 101i_2.jpg (195.43 KiB) Viewed 29921 times
- Elrick
- Main mouse: MX518
YES, have to agree, a near PERFECT layout without any need to modify whatsoever. Onya .
INDEED. After all the Xmas and New Year festivities, get on this keyboard and enjoy it to the fullest extent. Just don't spill any Coke or Pepsi over it.
Got a brother for my Portable PC III (I had the older model with AT layout), this time Lion Electronics branded ISO.
Same oddly non-yellowing caps. The build seems a bit more solid, which might indicate less use? The switches are also pine white Alps, but they sound and feel totally different. Bind a bit on corner press, feel stiffer and sound a LOT basier.
Did not really "need" it, but it was cheap? So...
(the protocol is also a bit funky - a bunch of keys including the nav cluster don't register as themselves, via Soarer's, but SHIFT and something else.)
- Polecat
Good eye. It's exactly the same width, but about an inch shorter, back to front, just like the difference between Gen2 and Gen3 102/Plus/Ultra models.
edit: I just opened it up, and this one has a single PC board, unlike the other Gen2 models. PC board is dated 890628 and copyright 1989, and interestingly it's identified there as "101T", a model number that so far hasn't appeared on any badge or label that I've seen. "Designed in the U.S.A." and "BBC" also on the board. The PC board and plate are attached to the top case with two screws (and a third shared with the bottom cover). Weather is too dark for outdoor photos, but I'll take some ASAP.
Oh, that’s annoying! I’d try to use Soarer’s converter to map them back to what they’re marked. Depends what the Shift + ?? keys are, I suppose. Also: which Shift. Soarer can see left vs. right, while the keyboard may be playing around with that re: its own actual Shift keys.Jan Pospisil wrote: ↑23 Dec 2021, 09:50(the protocol is also a bit funky - a bunch of keys including the nav cluster don't register as themselves, via Soarer's, but SHIFT and something else.)
- dcopellino
Edit: I asked and now answer by myself at once updating this post as follow. The item arrived sound and safe in a surprising record time of just a bit more than a week from Japan to Italy, costing me about €50 due to DHL courier for custom fees. The 5576-001 is in pristine conditions missing only two top keycaps I'm going to replace with some standard model m top keycaps that will be filled out of about 3.5mm.dcopellino wrote: ↑19 Dec 2021, 15:11Hello there, I've just bought an IBM 5576-1 with this auction on Yahoo Japan through buyee. https://page.auctions.yahoo.co.jp/jp/au ... 1026501168
I'm also curious to test this new spray product I bought for sanitising my new acquisition. Ad maiora.
Customs are charged by your country's government, not the sender's, so this is an Italian experience, not necessarily the same as I'd have over in Scotland RULE BREXITANNIA: WE WON THE WAR!! I'd consider 50 bucks a lucky spanking. Her Imperial and Britannic Majesty's Customs and Excise has beaten me for much more, many times in the past, even before all this.dcopellino wrote: ↑27 Dec 2021, 20:23Edit: I asked and now answer by myself at once updating this post as follow. The item arrived sound and safe in a surprising record time of just a bit more than a week from Japan to Italy, costing me about €50 due to DHL courier for custom fees.
- dcopellino
Yes it is. You are right as almost always, I'd say. I'm still crying at the thought of when I bought a non-destructive usb converter for the IBM 3172 from Singapore that strangely got stuck in UK custom....and it was a bloody spanking. You just have to hope for a massive BREXODUS at this point..... Please move to Italy, the real keyboard paradise. You certainly don't lack the right sense of humor which is essential to live here......
- dcopellino
Whenever want you are welcome back to Naples.
As for the idiom, it doesn't matter. Here we use gestures...
- Main keyboard: Kinesis Advantage2, JIS ThinkPad,…
- Main mouse: I like (some) trackballs, e.g., L-Trac
- Favorite switch: #vintage ghost Cherry MX Black (+ thick POM caps)
I recently got an adjustable footrest (Kensington SoleSoother), I thought those were just gimmicks, but it's such a nice quality-of-life improvement.
- DT Pro Member: 0011
- thefarside
I’ve been wanting to try a Dell for a while and got this for a good price due to the left control key having a broken stem. I’ve fixed this issue on other alps keys by super glueing the stem back on and making sure it’s aligned correctly. A little Nyogel on the stem and hole for the alps insert and everything works well.
It’s has black simplified alps and they don’t sound or feel too bad, but feel like they could benefit from a cleaning and restoration.
- daemonspudguy
- Main keyboard: Unicomp New Model M 103 Key
- Main mouse: Some RedDragon branded gaming mouse from China
I didn't buy it, but I recently received a Unicomp New Model M as a graduation gift from my grandparents. It's lovely.
- Bjerrk
That's a graduation gift I can get behind! Can you compare it to other eras of Ms?daemonspudguy wrote: ↑13 Jun 2022, 05:05I didn't buy it, but I recently received a Unicomp New Model M as a graduation gift from my grandparents. It's lovely.
- daemonspudguy
I can compare to it's direct predecessor, the Ultra Classic. It's far better than the Ultra Classic in every way. Any other eras I can't compare it to because I've only used Unicomp Model M boards. I can say it still weighs 1.7 kilograms.Bjerrk wrote: ↑13 Jun 2022, 15:38That's a graduation gift I can get behind! Can you compare it to other eras of Ms?daemonspudguy wrote: ↑13 Jun 2022, 05:05I didn't buy it, but I recently received a Unicomp New Model M as a graduation gift from my grandparents. It's lovely.
