I just make a survey in MediaVida (spanish gaming forum) about the use on Mechanical Keyboard, here are the results (first 100 people):
¿Mechanical or Rubberdome?
Brand
Actual using switch
First choice switch
Global preference for a switch
¿ISO or ANSI?
¿Layout?
¿Wrist rest or not?
The survey is in spanish but you can complete if you want and i will update the results:
https://docs.google.com/forms/d/1kPPOBt ... A/viewform
If you don't understand something just ask here, i will try to translate tomorrow anyway
