it's finally time for me to sell a major part of my collection, partly because I'm running out of space, partly because I don't use all the stuff around and partly because I could use the money for more useful stuff.
For sale are:
Touchstone 2 Rapid Data Controller, Oak Full-Travel Membrane switches, without cable, has two different DIN sockets, dirty 5€ plus shippingSold
Touchstone keypad (1).jpg (893.87 KiB) Viewed 11533 times
Touchstone keypad (3).jpg (840.89 KiB) Viewed 11533 times
Touchstone keypad (4).jpg (871.75 KiB) Viewed 11533 times
Touchstone keypad (6).jpg (873.44 KiB) Viewed 11530 times
Touchstone keypad (5).jpg (896.73 KiB) Viewed 11533 times
Atari AT layout keyboard, white Space Invader switches, missing keycaps, dirty 15€ plus shippingSold
Atari Space Invader.JPG (2.04 MiB) Viewed 9835 times
APC Operator keyboard, Unknown membrane switches with inverse crossmount, ISO layout, clean, metal case, including manual 30€ 20€ plus shipping
APC Operator (2).JPG (2.05 MiB) Viewed 10931 times
Topre K1-00, Topre short-throw switches, JIS layout without regular ANSI legends, in original packaging, virtually mint condition, internally converted to USB with a Teensy 2.0 and Soarer's Converter (PS/2 plug is still connected and can theoretically still be used), German legends are just cheap stickers and can easily be removed, some keycaps have been moved to get a better ISO layout 130€ plus shipping
Topre K1-00 (1).JPG (1.91 MiB) Viewed 10931 times
Topre K1-00 (2).JPG (2.07 MiB) Viewed 10931 times
Topre K1-00 (3).JPG (2.1 MiB) Viewed 10931 times
Topre K1-00 (4).JPG (2.16 MiB) Viewed 10931 times
Topre K1-00 (5).JPG (2.15 MiB) Viewed 10931 times
Topre K1-00 (6).JPG (2.05 MiB) Viewed 10931 times
Freebies (You have to take them all together, no separate sales!): Gone
Olympia keyboard, some kind of dome with slider switch, MX compatible lasered keycaps, dirty
Olympia keyboard (1).jpg (893.34 KiB) Viewed 11530 times
G84 innards, Cherry ML, yellowed pad printed keycaps; bought this from 7bit, apparently it is some kind of prototype G84
G84 innards.JPG (2.08 MiB) Viewed 9839 times
Mystery keyboard, dome with slider, ISO DE MX compatible keycaps, some doubleshot
Mystery dome with slider.JPG (1.9 MiB) Viewed 9839 times
Broken Model M2, ANSI layout; I got this as a Secret Santa gift a while ago and my Santa said he replaced all the caps and that it was working for him, but when it arrived at my place it was broken
Broken Model M2.JPG (2.15 MiB) Viewed 9839 times
Chicony KB-5191, Mitsumi Miniature Mechanical switches, ISO DE layout
Mitsumi Miniature Mechanical.JPG (2.16 MiB) Viewed 9839 times
All of the above is not including shipping! Shipping to Germany should be around 5€, the rest of europe 9-15€, international higher. Please ask for a personal quote, the values given are just ball park numbers; especially if you buy one of the heavier boards or multiples it'll go higher.
If you need more pictures, just ask! If you think that the prices are too high, tell me! Prices are negotiable.
Archive:
Cherry WoB doubleshot keycaps, ISO DE, a few caps missing, super shiny 25€ plus shippingSold
Apple M0110, Alps SKCC switches, french ISO layout, caps clean, case dirty and a bit yellowed, handwired/converted to (Micro-)USB with Soarers Controller, can include original PCB, replaced Caps Lock locking switch with regular switch and lower Caps Lock keycaps (can reverse that, if you wish), replaced Enter switch with Mitsumi standard mechanical (can put in a regular SKCC switch, I just didn't have another one back when I converted it) 75€ plus shippingSold
Silitek SK-8801B-2D, Silitek dome with slider switches, MX compatible doubleshot keycaps, slightly dirty 10€ plus shippingSold
Telefunken BTX-Tastatur FZ 680, Marquardt Series 6180 switches, MX compatible lasered keycaps, BTX receiver box also included if you want, dirty! 20€ plus shippingSold
Marquardt Mini, Marquardt Series 6184 switches, MX compatible keycaps, slightly dirty
More info: wiki/Marquardt_Mini 40€ plus shippingSold
Bavarian G81-3000, Cherry MY switches, mostly MX compatible lasered thin keycaps, stabilized keys not MX compatible, no cable, paint on corners sligthly chipped 20€ plus shippingSold
Cherry G80-0530, MX Black, PCB mounted, German ISO (kinda) layout, like new with small dent on F10,
I don't really want to let this go, since it's so beautiful, but that's also the reason I can't bring it over my heart to use the keycaps or switches elsewhere. 60€ plus shippingSOLD
More pictures here: photos-f62/cherry-g80-0530-commodore-pc ... t8736.html
Aquarius CSK-2102, complicated white ALPS, plate mounted, German ISO layout, shiny pad-printed keycaps, AT DIN5 connector, AT/XT switchable, one of the keyboards that started the hobby for me, cleaned, 30€ plus shippingSOLD
Liberty keyboard, white linear NMB Hi-Tek (Space Invader) switches, unknown protocol, RJ12 connector, new in mangled box, pictures of the unboxed model are from my second one, 30€ plus shippingSOLD
Cherry G80-3422LAMIT, from this GB, MX Black, PCB mounted, PS/2 connector, missing all three blank 1.25u keycaps and spacebar, almost NIB, 10€ plus shippingSOLD
Cherry G81-3000LPNXX, MY switches, ISO layout with custom pad/laser printing (not by me ), NIB, 15€ plus shippingSOLD
Alcatel SEL military keyboard, German layout, unknown switches (maybe Reed switches), doubleshot keycaps, kinda MX compatible (ridges hit the MX housing), broken switch stem on right shift and -_, not cleaned, full metal housing, heavy! 30€ plus shippingSOLD
ICL 16022, grey tactile NMB Hi-Tek switches (space invaders), British layout, from this auction: http://www.ebay.de/itm/302137233324. Selling, because I didn't like the switches. 25€ plus shippingGone
30x Nixdorf MX Blacks, good condition 50€SOLD
Unknown board with 90-100 Green ALPS switches, weird mix of German AT layout and standard 102 key layout, pad printed, the switches are still very smooth, maybe very very slightly dusty. You would want this for the switches, not the keycaps or case (both very dirty). For a few Euros more I will desolder the switches for you. Pics will follow. 35€ plus shippingSOLD
Apple M0118, Salmon Alps, German layout, yellowed, dusty, sticker on top case 30€ plus shipping
Various G80/81 cases, with or without winkey tab, not cleaned, 5€ plus shipping
2xG83-3000SAD, rubberdomes, dirty, don't even know who would want those, 5€ plus shipping
Shure SRH840 Headphones, doesn't probably fit in here, but I figured I could try before they go up on Ebay. Comes in original packaging with all the original content plus extra velour-pads (on the headphones right now), thicker faux-leather pads from a SRH940 and a braided 1.2m after-market cable. They are in very good condition, a bit dusty and a few minor scratches on the aluminium Shure logos on the sides. 70€ plus shipping Now on Ebay: http://www.ebay.de/itm/282267577891
Regards
Nuum
Aquarius keyboard and G80-3422LAMIT are gone, the Alcatel SEL keyboard is pending. Added some Shure SRH840 headphones, maybe someone on here is interested in them, else they go on Ebay soon.
Added Nixdorf MX blacks, German Apple M0118 and a Green ALPS board.
Prices are negotiable, I'm especially not sure about the Nixdorf switches. If the prices are too high, tell me!
Pictures will follow next week.
Sorry for being a complete noob, but can this Cherry G80-0530 be connected to a modern computer in some feasible fashion? I don't mind using 2-3 adapter cables to finally reach USB, but I do not have the equipment or time to play with anything significantly more complicated.
marijan wrote: Sorry for being a complete noob, but can this Cherry G80-0530 be connected to a modern computer in some feasible fashion? I don't mind using 2-3 adapter cables to finally reach USB, but I do not have the equipment or time to play with anything significantly more complicated.
I might be interested in the Telefunken, can you tell me a little about the keycaps?
Do you know whether they are PBT/ABS? How dirty/used are they? It's hard to tell from the pictures, if they are only dirty, or also a bit yellowed.
Nice. Didn't realise how easy it was to connect old keyboards. Now I am really tempted to buy one of model Ms. Or should I just hold my horses and try out XMIT hall effect board when it finally arrives.
Seems my inner geek got hooked up on keyboards even before getting the first mechanical one
Now I am already scouring through all the posts, waiting for some seriously underpriced nice keycaps.
Sankart wrote: I might be interested in the Telefunken, can you tell me a little about the keycaps?
Thanks in advance and have a nice day.
Very few keycaps, like Enter, Ctrl, left shift and spacebar are slightly yellowed, it's hard to capture on camera; the rest is fine as far as I can tell. The keycaps are therefore most likely ABS, although none of them has shine. They have pad printed legends (rimless) btw, not as I mistakenly said lasered ones.
Ray wrote: b**a did bid on your headphones and someone else got them [/brownfont]
I suspect this was another b**a, judging from the other items he bought he is not the one we know for stealing all the nice keyboards from HaaTa and others.
XMIT wrote: [...]
I feel bad for whoever your Secret Santa was this year. You're getting rid of so much amazing stuff, you must have been very difficult to shop for!
I'm okay with the keycaps being ABS, if they are in good condition, only problem I currently have justifying this purchase is that I got no interest at all in the keyboard itself. So if anybody is interested in getting the keyboard, but not the keycaps and wants to split the cost, I'd be down for that. Otherwise I think I'll pass, december is expensive enough as is.
Bump! This weekend is the last chance to get one (or more) of those board shipped before Christmas! If you are from Germany it would probably even arrive before Christmas.
At first I thought you were mistaken. After all, sure you meant Series 6184! Series 6180 is the highly rare old Marquardt switch that we hardly ever see. But no, you really do have 6180. I hope that whoever buys that keyboard documents it.
