Whitening a yellowish spacebar on an IBM Model M keyboard: HOW?
devhdb
22 Dec 2016, 17:54
I have a 'rebel' space bar which, after the years has become quite yellowish and doesn't come out white enough as the rest of the keys after some thorough cleaning with this method:
https://geekhack.org/index.php?topic=32 ... #msg623677
I wonder if it's made of a different kind of plastic...
So what do you do to whiten/bleach key caps such as the spacebar? Shall I use bleach or would I risk damaging the plastic by doing that?
Ratfink
22 Dec 2016, 18:04
It's a Greenock model M, isn't it? A lot of those have ABS spacebars, which are prone to yellowing. A treatment with Retr0bright should make it shiny and new again (for a few years, at least).
devhdb
22 Dec 2016, 18:07
Oh, thanks Ratfink, I'll try that!
Techno Trousers
100,000,000 actuations
22 Dec 2016, 18:28
Worst case, you could buy a replacement PBT space bar. Unicomp sells them, but they might not quite match the vintage color.
