Swapping springs in Gateron Browns
- Stabilized
Depends if it has a plate that is designed for switch top removal or not. If the holes aren't perfectly square then it's probably compatible, but if it doesn't then it's not.
Pretty much all of the Ergodox cases/plates I have seen support switch top removal, if the holes look like this then it's suppported:
I don't think there's any other problem with swapping out springs, I have done it a number of times when modding my keyboards and as long as your careful to not bend the contacts then you'll be fine.
