Keycap swap between Realforce 104UG HiPro and standard RF104
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
Yes, this has come up before.
It comes down to this:
1. The HiPro keys have extra tall key switch bodies that you'll need to swap out.
2. LCtrl is different on HiPro and a regular Realforce, meaning you'll either need to modify your plate or create a modified key cap. I prefer modifying the plate.
Good luck!
Good luck!
I thought the different Ctrl key only applied to the 87U because of the LED. What's the difference with the 104U's Ctrl? And how does one go about swapping out the "extra tall key switch bodies"?XMIT wrote: Yes, this has come up before.
Good luck!
