49-Key Model M
just_add_coffee
27 Apr 2017, 19:29
So I got this from Orihalcon.
Here are some pics of IBM Part #1393915. For science!
Model M's capacitive membrane, flippers, and case; Model F's barrel plate and barrels.
orihalcon
28 Apr 2017, 03:02
Looking good! I never really took one of them completely apart, but at least the foam looks decent.
In theory, you could make a Model F PCB and add F flippers, install an xwhatsit and you'd have a true model F! If I had more beyond those, I'd consider doing it, but I don't know if the increase in cost would still leave many people interested.
rsbseb
-Horned Rabbit-
28 Apr 2017, 05:00
F barrels over membrane, interesting. What's your plan for this board?
28 Apr 2017, 08:07
The M's membrane isn't capacitive ;) .
orihalcon
28 Apr 2017, 15:40
True, model M membranes are not capacitative. Was saying you could make a Model F PCB to go under the barrels instead of the membrane, add Xwhatsit controller, and you've got yourself a 50 key Model F.
The template already exists for these PCBs as these are identical internally other than the membrane instead of PCB to a 4704 Model F 50 key. It even has the nubs that hold the F PCB in place. Pretty clear that they re-used all model F tooling for the main board for these M50's and just stuck membranes inside instead.
Just need to reproduce this PCB:
just_add_coffee
28 Apr 2017, 20:03
rsbseb wrote: What's your plan for this board?
Oh, something like this ...
8-)
just_add_coffee
28 Apr 2017, 20:08
orihalcon wrote: I never really took one of them completely apart, but at least the foam looks decent.
That's amazing really! There was a little it of dust and a bit of corrosion on the barrel plate, but between the plates and the membrane itself were very clean. I thought for sure you had gotten in there and cleaned a little bit.
