Or maybe it's just worth whatever wire I can scrap from it. What are my odds? It doesn't arrive until next week.
I got an S-66 for $10 on craigslist. Integrated dome w/ 3 SKCL Green LED's. Alps spherical caps.
Hey thats my build!Findecanor wrote: BTW, a previous thread with a very similar keyboard from a Canon S-14 typewriter, used for scavenging keycaps for use with Alps switches: : Photos: KBP V60 Build with SKCM Amber and Canon HiPros.
Note the use of Alps stabilisers - some keyboards with Alps switches have Costar-style stabilisers instead.
Do the the plate holes for Alps SKEW integrated domes fit Alps SKCL mechanical switches? In that case, I think it could be more interesting to put that or Matias switches in with direct wiring, just to fully utilise the whole keycap set and layout.
Yes SKEW and SKCM/SKCL plates have the same hole size. PCB's are incompatible however.
