New in the forum. My first keyboard was an ADB Keyboard with orange ALPS. Spoiled since...
I tried many other switches and I like a few but I guess I tend to lean towards ALPS.
While I have experience soldering, it is something I'd rather avoid in my small apartment. I'm quite familiar with disassembling ALPS for cleaning/maintaining, as per Chyros' video (thanks Thomas!) and I have the following question to see if I can get away with not soldering:
Can I take an (for example) Apple M0116 with PINK switches, open the switch, remove top housing, slider, "click leaf" and spring, (leaving the bottom housing and the contact leaf as they are soldered to the board) and then mount it again with the top housing, slider, "click leaf" and spring of an ORANGE switches? If I do that with every switch, could I transform a PINK board into an ORANGE one? I don't know if ALPS share bottom housing and contact leafs (or at least for some of the switches)
Now, my question involved quite a similar cousin's (PINK and ORANGE) and maybe it is possible... but... could we extrapolate this to other ALPS? Ideally modifying a PINK one into BLUE ones?
Maybe it might be more difficult with Ivory dampened ones because of the dampening sides of the slider? And I'm almost certain that you wouldn't' be able to do so with Monterey Blue ones as they seem to have different housing...
Anybody that can shed some light on this kind of "switch housing compatibility matrix"? I did a search first but couldn't find anything...
Apologies for the length of this first post and thanks in advance.
