Essential:
Matches the layout and dimensions of the classic Model M (I think) (EDIT: looks like I got this wrong, sorry)
USB interface (or one that a Raspberry Pi can use with an adapter)
Desired:
Status lights integrated into the lock keys
Trackpoint pointing device (or off-brand clone)
Tactile switches
The reason for this is that I'm turning a vintage portable computer (Amstrad PPC 640) into a Raspberry PI casemod. The first requirement is pretty much non-negotiable, because it needs to fit into the same physical space as the original keyboard once I remove it. I'm 99% certain that it's the same measurements as the IBM Model M, because of posts I've found elsewhere by people doing similar things. If it helps, I've measured from one edge of the keys to the other (specifically, the edges of the cutouts), and it's exactly 17 inches (or near enough that I can't tell). Elseweb, I found someone who got a Lenovo SK-8825 to fit with a little work.
The second requirement is also pretty important, because the Pi requires USB input. I'm not sure I can rely on, say, a PS/2-USB adapter, because I've read posts about then not working reliably with the Pi. However, if the keyboard in question is a modern one, I don't expect that to be a problem.
The integrated status lights are on the list because the PPC's keyboard has them. If the one I replace it with doesn't, that means I'd have to drill new holes into the case to accommodate them, and I'd really prefer to avoid that. I also considered drilling holes in the keys and running the LEDs over there, but again, I'm not experienced enough to know if that's a practical solution.
The Trackpoint (or clone of such) is mainly because I'll need mouse input at times, and I'd really like to preserve the retro aesthetic of this thing while it's in use; I feel like having a mouse plugged into the side will compromise that. Plus it would be nice to mix a little Thinkpad DNA into this ridiculous frankenbeast I'm making.
The switch preference is just, well, preference. I like being able to feel the click, but I don't want it to sound like I'm ringing the Bell of Awakening.
I've been searching various keyboard vendor sites, but I'm having a hard time finding what I'm looking for. I don't know if it's because I'm not using the right search terms, or if my ideal keyboard just doesn't exist. This place seems to really know keyboards, though, so I figured it was a good place to ask.
So, does anyone know where, or even if, I could obtain such a keyboard? What do I need to be searching for and/or filtering by? Thanks in advance for any help you can give me.
