Whitefox 3d
-[°_°]-
08 Jun 2018, 23:47
More details later and I'll also post a full hand-wiring tutorial but anyway...
This is a whitefox you can print @ home https://www.thingiverse.com/thing:2952008
The source is on onshape and freely accessible here in case you want to change the layout or anything.
Each piece is less than 20cm, so it can be easily printed on any consumer grade printer. I shot a short video with some details if you are interested.
Print time of the whole thing at a decent resolution is about 12 hours. If you are interested in hand wiring but a little intimidated I'm writing a series of tutorials about it.
kakan
09 Jun 2018, 12:46
Nice! Did you make any changes from your other whitefox/nightfox except for the top screwholes?
-[°_°]-
09 Jun 2018, 16:25
the case is slightly different to make it easier to 3d print and more sturdy (because of plastic instead of aluminum)
-[°_°]-
18 Jun 2018, 18:24
And this is the end result! Hand wired on /dev/tty keycaps :)
green-squid
25 Jun 2018, 21:45
Looking good! These are the caps you designed, right?
chuckdee
26 Jun 2018, 02:49
Does it work with any of the whitefox pcbs that are out there (I:Cs or MDs)?
Also, what infill and thickness do you recommend?
-[°_°]-
27 Jun 2018, 10:31
green-squid wrote: Looking good! These are the caps you designed, right?
they are indeed!
chuckdee wrote: Does it work with any of the whitefox pcbs that are out there (I:Cs or MDs)?
the case is for hand wired keyboards only.
I printed with 6 top/bottom layers and 5 side-walls. That gives a lot of stability, but you can go away with 4 top/bottom layers and 4 side/walls, I wouldn't go lower than that. Infill 25%.
In the mean time I posted a video about hand wiring
https://www.youtube.com/watch?v=LVzpsjFWPP4
Soon to come a full (written) tutorial.
chuckdee
28 Jun 2018, 04:31
Thanks for the information!
obfuscated
28 Jun 2018, 17:03
This keyboard would be a lot sturdier if you add several posts in the middle which touch the bottom to prevent the top from bending.
-[°_°]-
28 Jun 2018, 18:52
obfuscated wrote: This keyboard would be a lot sturdier if you add several posts in the middle which touch the bottom to prevent the top from bending.
the plate is 4mm, it doesn't bend
obfuscated
30 Jun 2018, 21:32
I can see that it is bending in your handwire video. :)
chuckdee
30 Jun 2018, 22:03
^ I didn't notice it bending. :?:
-[°_°]-
01 Jul 2018, 09:05
obfuscated wrote: I can see that it is bending in your handwire video. :)
it probably bends less than aluminum honestly
