Hello does anyone here have firm information on the amount of macro characters that can be stored in Soarers converter? I’ve created a few F Key macros on my M122 And keep getting an error that the macro block is too big.
Similar question if Soarers has limits like that any alternatives for something that will let me do more macro key characters?
Soarers Macro Limitations
- Main keyboard: IBM Model M
- Main mouse: Logitech
- sharktastica
- Main keyboard: '86 IBM F Bigfoot + '96 IBM M50
- Favorite switch: Cap B/S, BOX Navy
I'm unsure what the macro limit per block is, but you could try separating the macros into their own macroblocks every so often as a quick fix. I encountered a similar issue when I was trying to make my entire 122's top function key row print email addresses. Separating them into their own macroblock (I put three or four macros per block) solved it.
- Inxie
- Main mouse: Lenovo Legion M500
I think this depends on the capacity of the controller used. The tools (which you need to disable Defender on because it flips its rocker) that are included with the utility can tell you how much free space you have.
Thank you for your help!sharktastica wrote: 02 Oct 2020, 18:03 I'm unsure what the macro limit per block is, but you could try separating the macros into their own macroblocks every so often as a quick fix. I encountered a similar issue when I was trying to make my entire 122's top function key row print email addresses. Separating them into their own macroblock (I put three or four macros per block) solved it.
