Matias debuts pro-grade Ergonomic Mechanical Keyboard at CES
- Matias
- Main keyboard: TOP SECRET unreleased prototype from Matias Labs
- Main mouse: Prototype Matias Mouse
- Favorite switch: Matias Click Switch
Just announced...
http://matias.ca/ergopro
http://matias.ca/ergopro/pr
Let me know if there are any questions.
- DT Pro Member: 0049
How do you connect both halves to the PC? Does each run to the PC, or do you connect one to the PC and then wire them to each other?
EDIT: Duh, I should learn to read.
All in all it looks like an interesting keyboard!
Bridge Cable
1 foot (30 cm)
- HaaTa
- Master Kiibohd Hunter
- Main mouse: CST L-TracX
- DT Pro Member: 0006
Neat!
Matias, was there a reason to go with standard staggering rather than mirrored staggering? Familiarity? Transitioning?
(mirrored would be something like a uTron).
Good question about a promising keyboard. Symmetric stagger feels right but could put people off as it looks wrong. Versus vice versa.
Matias Ergo Pro:
µTRON:
I know talking about unannounced products is off the table, but I do wonder when and how wireless functionality could be brought to a split ergo keyboard. Bluetooth controller in one half and a separate low power wireless connection between the two?
Matias Ergo Pro:
µTRON:
- DT Pro Member: 0011
Real nice! Most interesting new product from CES so far.
I think it would take me a while to get used to the right Alt key being so far left, but Microsoft users would feel right at home.
I see that the 6 key is on the right half-keyboard, opposite to where Microsoft, Goldtouch and Kinesis (Freestyle, Maxim) has it. Notice also where the right Ctrl key is ..
Edit: Added to Wiki.
- Broadmonkey
- Fancy Rank
- Main keyboard: Whitefox
- Main mouse: Zowie FK2
- Favorite switch: MX Black
And a new switch named quiet click? Are those half hight keys also using the same switches?
In any way, it's looking really good!
- Broadmonkey
- Fancy Rank
Yes, I most certainly think it is.
http://matias.ca/switches/quiet/
Edit: nothing like a bit of Cherry bashing, eh?
Great link. I see they are available to order aleady! (7bit…?) And they say the stem is grey colour for these guys. Wonder how well they'd go in an M0110.
But this is interesting if you read between the lines:
Don't expect Matias linears…More tactile than Cherry.
For proper tactile feedback, you need a click leaf in the switch, or an equivalent mechanism. Cherry switches lack this. They are a linear design which is, by definition, NOT tactile. For users who like linear switches, Cherry are the best, but they are NOT tactile.
- ماء
- Main keyboard: Soon
- Main mouse: Roccat Lua
- Favorite switch: Blacks to heavy>Lighter
noMuirium wrote:MX greys are weight training for your fingers!
i think cherry best for linear then intrested blues.....
- bhtooefr
- Main keyboard: TEX Shinobi
- Main mouse: TrackPoint IV
- DT Pro Member: 0056
Damn.
Matias certainly knows how to get shit done.
Interesting that they're playing with reduced pitch. They're down to around 14.2 mm vertical pitch for the smaller keys! (Still 19 or 19.05 horizontal, though.)
- matt3o
- -[°_°]-
- Main keyboard: WhiteFox
- Main mouse: Anywhere MX
- DT Pro Member: 0030
not interested but I'm glad it exists
- bhtooefr
Oh now this just got even more interesting.
From the Secure Pro thread on Geekhack:
I must say, I wasn't expecting them to push Alps quite THAT far in narrow pitch, even if it's only vertically. (Also, my postulating that 16.75 mm pitch Alps was possible is only in the vertical direction (and Matias just went further than that), or if the switches are sideways, only in the horizontal direction. The switches are a lot wider than I was thinking. 18 mm is definitely doable though.)
That does mean that it's most likely a 15 x 5.5 U layout, so taller than a normal 60% by about 9.5 mm.Matias wrote:The 60% wll come next. We're planning to use the same arrow key + nav cluster as the Ergo Pro, giving you a 60% keyboard with full nav key support -- as I hinted weeks ago, a no compromises 60% layout.
- vivalarevolución
- formerly prdlm2009
- Main keyboard: IBM Beam spring
- Main mouse: Kangaroo
- Favorite switch: beam spring
- DT Pro Member: 0097
It's great to see another two-piece mechanical keyboard on the market (the other being the microTron).
The lack of symmetry in the design is something that throws me off. I thought that I did not care about aesthetics, but it seems that I do. Maybe I'm finally developing a finer taste.
- Vierax
- Main keyboard: Tipro MID KM128 Bépo layout
- Main mouse: Kensington Orbit Trackball
- Favorite switch: MX Clear / MX Grey (under thumbs)
Yeah the design is more like the Kinesis Freestyle than μΤron, it's unfortunate but it's a first step to a fully ergonomic keyboard. Thanks Matias for the effort !
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
Non-standard key caps sizes are bad. Should there ever be an Alps key caps group buy, it will not include those tiny key caps.
Also, normal key caps on those moster-key postions (bottom row) will look wrong.
Huh? Some Cherry MX variants are surely tactile. What is he on about? Is he referring to the MX Brown not being tactile enough? I could agree with that, but MX Clears and Blues are tactile enough. The tactile point is located different in the stroke, but they are still tactile.Muirium wrote:More tactile than Cherry.
- bhtooefr
Yeah, that's downright false. And blues and greens even have a dedicated part for adding tactility and clickiness.
- HaaTa
Bahahaha, Cherry the best for linears, bahahaha.Muirium wrote:Great link. I see they are available to order aleady! (7bit…?) And they say the stem is grey colour for these guys. Wonder how well they'd go in an M0110.
But this is interesting if you read between the lines:Don't expect Matias linears…More tactile than Cherry.
Excluding some truly awful linears, I'd say they are pretty mediocre linears (this includes all Cherry linear variants, old and new).
The slider design itself, while better than some of the earlier Cherry switches is still pretty crap. Too much friction.
- Kurk
- DT Pro Member: 0027
Nice to see a split keyboard with mechanical switches, and it's also good to see so much product news from Matias.
But why o why did they stick to the stupid standard staggering. IMO, the most important non-ergonomic feature of ordinary keyboards is exactly this staggering.
Because the people at GH and DT are not like regular consumers. Standard staggering -> more sales.
BTW, from the Cherry reveals new MX switch! thread
Matias wrote:Nice to see that Cherry is paying attention to what others are doing.
We have a pretty big announcement coming next month. I think they'll have a harder time copying this one.
- bhtooefr
You know, now that actually makes sense.
The .75 U tall keys are, AFAIK, impossible on Cherry MX.
