IDENTIFY THE KEYBOARD thread
- TNT
- DT Pro Member: 0250
Looks very similar to Compaq's model F clones: wiki/Key_Tronic_Model_F_clone_series
- SlowTyper
- Main keyboard: Cheap junk
- Main mouse: Logitech MX 518
- Favorite switch: Gateron Yellow
So foam and foilTNT wrote: ↑21 Mar 2021, 20:18Looks very similar to Compaq's model F clones: wiki/Key_Tronic_Model_F_clone_series
- Keybug
- Main keyboard: so many!
- DT Pro Member: 0208
Strange Cherry fish, should be a pretty great little workhorse! Likely MX blacks under thin PBT keycaps. Does anyone know the model number?
- Strange Cherry fish2.jpg (361.53 KiB) Viewed 5437 times
- kbdfr
- The Tiproman
- DT Pro Member: 0010
It’s a G81-8308, it has awful MY switches.
And yes, it is a pretty great little workhorse with 24 programmable keys, like its predecessor the G80-2100..
- Keybug
Damn! And to think I just missed this beautiful NIB mother of a Siemens terminal keyboard...
- Screenshot_20210322-140615-2.png (1.86 MiB) Viewed 5418 times
- Screenshot_20210322-140415-2.png (2.19 MiB) Viewed 5418 times
- Keybug
But then again, maybe it isn't G81! Thanks for pointing me in the right direction, though.
- scr_cherryg81_8308_eng_pdf__[Page_Cherry_G80_830_22032021_173144.jpg (48.91 KiB) Viewed 5415 times
- photekq
- Cherry Picker
So unlucky. That's such a beauty. I don't suppose there were any pictures of the label? I hope it turns up somewhere so we can at least identify it
Please stop commenting this on every Siemens/Nixdorf branded Cherry board The only boards with "Nixdorf blacks"/"Nixies" are the Nixdorf Softkeys boards [1] [2], which are easily differentiated from the Siemens/Nixdorf boards that were OEM'd by Cherry themselves.
- Main keyboard: SINGAKBD x TGR Unikorn
- Main mouse: Some piece of crap
- Favorite switch: PCB Mount Vint Blacks
No, it probably did not.
- Main keyboard: Huntsman Mini
- Main mouse: G305
- Favorite switch: Gateron Milky Yellows
Found this at work. wanted to know if its worth anything.
- keeb.jpeg (393.77 KiB) Viewed 5302 times
- keeb2.jpeg (426.8 KiB) Viewed 5302 times
- Palatino
- Main keyboard: Fluctuates.
- Main mouse: Of no interest.
- Favorite switch: Too early to tell.
- Palatino
They keycaps look nice - they would definitely get some interest on their own. As to the keyboard itself, it depends a bit on the connector and how usable it is. I for one like it: many strange buttons is a plus!
- Main mouse: G305
i like it too! honestly wouldn't mind selling it. But it is a ps2 connection on it. It was covered in plastic its whole life. sop the condition of it is very good.
- kbdfr
- The Tiproman
The G80 version of the 8038 is not a Cherry model, but a modification made by a third party (don't remember the name at the moment), according to which they make them only with MX browns.
- Keybug
Bugger, you were right, of course. G81 it is! Still, a great little tank of a board. Not sure I will be able to find a use for it, though. Typing on it is horrible, of course.
- kbdfr
- The Tiproman
The innards of a G80-8000 would fit, but while the G80 has a flat cable as a connector, the G81 has a plastic sheet with printed tracks. Apparently no way to make the contacts fit, I fear, even if the connections have the same measurements and probably the same configuration.
But well, I'm not a keyboard tinkerer, of course.
Would be grateful for how-tos - preferably excluding soldering
- hellothere
- Main keyboard: Lots
- Main mouse: CST2545W-RC
PS/2 isn't a problem. PS/2 to USB adapters cost around $6 US. It would be nice if you remove a cap to show us the switches. I'm thinking Cherry, but I could be wrong.austinmc32 wrote: ↑23 Mar 2021, 01:20i like it too! honestly wouldn't mind selling it. But it is a ps2 connection on it. It was covered in plastic its whole life. sop the condition of it is very good.
Gotta love a keyboard that has both a "Meth" key and a "THC" key.
I'd probably put a bid on it, too. I also like lots of additional keys.
- Go-Kart
- Main keyboard: HHKB & AnyKey
- Main mouse: Orochi v2
- Favorite switch: Topre 45 g & MaxiSwitch D/S
- Palatino
I've draw a blank on this switch - and the keyboard too. The switch is clicky, perhaps an Alps clone of some sort, but with a simple rectangular slider like an SMK 2nd Gen switch. Doesn't feel too bad at all. Does anyone recognize it?
- Go-Kart
I saw/bid on that Fullmark! I had the guy shoot me a pic of the switches and it just looked like an Alps clone but I couldn't discern anything further due to bad picture quality. Now I can see them better, it still doesn't help all that much
- Main keyboard: HHKB Pro 2 and IBM Type F
- Main mouse: Logi M570
- Favorite switch: Topre and Bucling Springs
Ordered one simply because I was too curious, now will need to figure out how to convert it...
- zrrion
- Main keyboard: F122
It looks a lot like a KPT switch, but the top housing isn't quite right for that
I have a Fullmark board with what looks like a white version of the same switch. I thought I identified the switch, but have subsequently forgotten what it was. My Fullmark board is identical to two other boards I have with ISNJK-168/268 FCC ID (Limtech) (one with SKCM white, one with AO2 clones), apart from the label and PCB - the same as wiki/Brain_KB-9001S, but without the RB88. Note the 368 number on the plate. Sorry for the garbage photos.
