Can someone identiy this keyboard and swithes?
Lynx_Carpathica
08 Aug 2016, 18:23
Hello!
I just recived this keyboard from my friend. It's not in the best condition, but hey, it will do as a generic "clicky tactile mechanical kb". I removed the cable, needs some soldering and heat shrinking job.
Can someone please identify theese switches and the type of the keyboard for me please?
And can someone tell me how to disassemble theese switches to lubricate them?
Thank you for any info!
08 Aug 2016, 18:35
Tai-Hao Aruz switch, a nice Alps SKCM clone:
wiki/Tai-Hao#Keyswitches
Looks like your FAME keyboard has taken some damage. :o
Welcome to DT!
Lynx_Carpathica
08 Aug 2016, 18:43
Thank you. Can you tell me how can I take theese switches appart?
08 Aug 2016, 18:53
I don't remember if the top comes off like on Alps SKCM. Since I don't have any here I can't check that now. Dra should know:
photos-f62/let-s-have-a-look-at-the-t-a ... hilit=FAME
You can also have a look at this:
review-f45/tai-hao-fame-th-5539-aruz-sw ... hilit=FAME
terrycherry
08 Aug 2016, 19:38
First of floor, desloder all switches.
You can use the - screw driver to open the top of the switch shell(two side plastic lock) carefully. The plastic lock can break easily. And I suggest that don't take out two contact leaves because they're thin and need much force to pull out. The result is less then 40% switches were completed to disassemble all parts.
This is the poor disassemble switch design I ever seen.
Lynx_Carpathica
08 Aug 2016, 22:11
If I desolder it, will it fall out?
terrycherry
09 Aug 2016, 10:20
Yes, it takes out from the plate easily.
Lynx_Carpathica
10 Aug 2016, 11:30
Got it!
Can I wash the bottom part of the switches, containing the contact leaves?
Dishwashing liquid, and then rinse them off with cold water? Or it will leave corrosion?
I took appart All of the switches, and I'm soaking the sliders, and the top half of the switches. Can I soak them too?
10 Aug 2016, 12:02
Lynx_Carpathica wrote: Got it!
I'd advise never to wash or rinse any electronic components with water. It promotes corrosion, leaves residue, and is hard to get out of tight spaces. If you want to use some kind of fluid, use iPrOH which is electronics-safe.
Lynx_Carpathica
10 Aug 2016, 13:45
I only have 90 something % ethanol.
Wodan
ISO Advocate
10 Aug 2016, 13:48
Nastrovje!
Lynx_Carpathica
10 Aug 2016, 15:02
i don't speak russian. :(
10 Aug 2016, 15:06
Wodan wrote: Nastrovje!
Lynx_Carpathica wrote: i don't speak russian. :(
You don't need to. :lol: Prosit. :mrgreen:
10 Aug 2016, 15:07
Lynx_Carpathica wrote: I only have 90 something % ethanol.
You just have to pour out 10% to obtain pure ethanol :lol:
(just as a precaution: this is of course a joke!)
10 Aug 2016, 15:11
kbdfr wrote: (just as a precaution: this is of course a joke!)
Playing it safe kbdfr? :mrgreen:
10 Aug 2016, 15:28
You never know :lol:
As a matter of fact, I first wanted to say he can drink the 10% water out of it :lol:
10 Aug 2016, 15:31
kbdfr wrote: You never know :lol:
Actually your right, these days you cannot be careful enough when giving advice online. ;) I would not tell anyone what they can or cannot drink. :?
Wodan
ISO Advocate
10 Aug 2016, 15:34
I guess now I owe you a better response :)
It's a good idea to use something like pressured air to clean the lower switch assembly. There isn't much else you can do unless you want to go the extra mile and desolder everything, remove the switch components, clean them individually and then put them back into the cleaned shell.
10 Aug 2016, 16:25
Bah, ethanol is for pussies real men drink n-butanol!
(seriously don't drink n-butanol, you'll shit out your liver)
Lynx_Carpathica
10 Aug 2016, 17:48
Thanks guys! Shall I lubricate the sliders?
10 Aug 2016, 18:11
Lynx_Carpathica wrote: Thanks guys! Shall I lubricate the sliders?
Do they feel very scratchy?
Lynx_Carpathica
10 Aug 2016, 18:56
Tiny bit. What can I use?
Engine oil? Sewingmachine oil? Wd-40?
alh84001
v.001
10 Aug 2016, 19:12
These will attract dirt. I used WD-40-branded PTFE grease, which I got in local bauhaus. They only had spray variant, and if you can get brush variant, that would be better.
Lynx_Carpathica
10 Aug 2016, 19:22
Thanks, going to try it :)
10 Aug 2016, 19:44
Unless it's really bothering you I'd advise against lubing Alps-like switches until someone has found a way that actually works ;) .
Dra
11 Aug 2016, 23:52
Hey,
I know I'm late to the party and you emailed me about the switch disassembly but my DT email isn't my primary email and my current ROM doesn't push all my gmail stuff like it should.
Since you already figured it out on your own I'll just spoiler the disassembly
Latch of the switch, 1 per side, it's closer to cherry mx since the switch can't be opened while it's stuck in the plate
Top off, just slide a thin thing in there and lever it up, there's not a big bump to overcome so it should be fairly simple
funny that you should say that Chyros, the Aruz are already prelubed and you can definitely feel it :lol:
12 Aug 2016, 01:08
Dra wrote: funny that you should say that Chyros, the Aruz are already prelubed and you can definitely feel it :lol:
Probably why they feel so good, just like 1st gen Alps switches, and why they stand out so much compared to the other clones :) . I really enjoy my Aruz board :D .
terrycherry
12 Aug 2016, 03:52
Sorry late to reply. Use your own way or others advice to wash it both works.
Since I use the water with body wash for the 1st washing and the floor wash for the 2nd washing on the Ultrasonic cleaner.
And then using the Alcohol wet tissue to clean the switch parts in detail. Finally, landing it one day.(I used the dehumidifiers for few hours because of the Hong Kong wet weather)
These ways are not make it corrosion. Because the corrosion of copper will take a week in water. I test it before.
And the important thing is this dirty boy had been landed in raining day many times before you take it, so work it for your best.
Lynx_Carpathica
12 Aug 2016, 10:30
Thanks!
Lynx_Carpathica
12 Aug 2016, 21:14
I have linearmoded the keyboard. :D
Great for WinUAE :D
